Question about Maxtor Hard Drive
Laptop not recognising external HDD
I have a Maxtor external HDD that inadvertantly had the usb cable pulled out yesterday while it was being used to watch a movie (which was paused at the time). I thought nothing of it and turned the movie off and went on to cooking dinner. Later last night I tried to access my external HDD again and have had no luck since. When plugging in the LED on the HDD illuminates, the HDD initially makes a whining noise(which is repetitive as if it is stuck at a certain spot and is unable to skip past) after about 5-10 mins it stops making noise, the LED remains illuminated but my laptop still wont pick up HDD. I have tried to plug it into my wifes laptop and change the USB cable with other cables that I know work and have no joy with any.
  • 1 more comment
  • dsvowell Feb 03, 2009
    yes I have rebooted my laptop several times both with device connected and without. I have disconnected the HDD from the power source and plugged it back in. I have just checked my device manager and it my HDD wasn't listed. I have had no problems with my HDD until now.
  • Palmbeach
    Palmbeach May 11, 2010
    Check the drive's power unit. Although it is not good practice to pull out the USB cable while the drive is being written to or read from, it should not cause any damage, apart from perhaps some corrupted data on the drive. It should certainly not stop it from working.
    However, the switch mode power unit that powers the drive could have been damaged by a voltage spike. If it has been damaged, it is likely that the voltage would be ok if you were able to measure it, but the load on it caused by the drive, pulls the voltage down and that can cause the constant whirring, clicking or searching effect.
    Try a replacement power unit.
  • Tricia Scerbo
    Tricia Scerbo May 11, 2010
    Have you rebooted your laptop to see if that solves the problem? If you have a desktop pc, try connecting it there to see if you can access the drive. Does the drive show up in My Computer? If not, have you checked Device Manager to see if there are any conflicts? (There may not have been before, but pcs are like that!) Thanks
    Problem Solver:
  • 5 Answers
OH OH!!!!!
There are several things that this could be.
1) You didn't safely disengage your usb device and have lost or damaged info on external HDD.
could try scandisk or formatting drive.
2) USB cable may be damaged.
not likely but possible(Fix is replacing cable if that is the problem)(Drivers could get switched for device in very rare occasions of one or two, but not likely.)
3) This one is scary. Hard disk may have been spinning when bumped and the heads may may have broken off. Fix is to buy a new one if this is case.
If this drive is holding very important data, there are specialists that can retrieve most or all of your data for an extremely high fee, even if the external HDD is completely smashed up.
4) If external HDD is working but that file isn't, file may be damaged, try scandisk or replacing file is fix.
5) Your program reading movie may be fragmented. This is unlikely because you tried this on other system. If so replace program.
These are some possible things, but I am afraid I may not have given you good news,
Good luck(My guess is option 3 and I hope I am wrong.)
Posted on Feb 03, 2009
  • John  Davis
    John Davis Feb 03, 2009
    Ummmm...Device Manager wasn't mentioned with this person unless they have contacted you but even so that does not mean driver problem automatically. Cable replacement and find new hardware are cheap though and might be good first step. If device shows on puter try scandisk if that doesn't work....Ummmm
    May be time to get a new hard drive.
    I broke one of these in the past by pulling out cord and it made that sound and didn't show, I found ut I broke heads and messed up usb port on external HDD.
    Laf a lot gave good procedure for finding missing working device and if thaat is the case do it.
    Scholar:
  • 152 Answers
Since it's not listed in Device Manager, it needs to be reinstalled, or it is possibly another problem. Let's try the easy part first. Uninstall any software/drivers that are in your system using Add/Remove Programs. Then, connect the drive to the laptop with the USB cable and see if it is recognized. If so, you will be prompted to install the drivers. You can also try the Find New Hardware (in Control Panel) to see if it appears, then follow the instructions for installing the drivers. Let me know how that goes.
When I plug my maxtor in, I can hear it "thinking"
use an external usb ide( or if your hdd is sata,then use a sata cable)then insert to a working computer then you can copy your files
Feb 19, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
Seagat 500GB Portable GO external HDD not recognised on PC
first of all you should try it on deferent pc , if its ok then that leads us to insufficient power provided through usb ports , try using back usb ports not the ON-front, and if the problem still try using dual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.html and if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changed if you cant find a similar one you may buy a new empty cage
Mar 05, 2010 | Computers & Internet
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
Maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
Oct 15, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
External HDD is not working
You probably have conficker worm because it stops your pc from reading usb's or any external HDD. Or the worm might of infected your HDD since it spreads through usb and internet. Seriously you should get your PC scanned just incase. P.S. Its just a possibility.
Jun 09, 2009 | Maxtor Hard Drive
Maxtor 1000 GB external HDD not coming up on my laptop.
Try a program called GetDataBack the trial version lets you scan the hard drive for data, however you have to buy it to recover any data.
Feb 03, 2009 | Maxtor Hard Drive
Maxtor 250 GB SATA problem: Foreign disk problem
Simple you need to update your bios by downloading bios updates for you motherboard. Then it should recognise your HDD. The yellow triange just means your mboard does not have the necessary drivers to recognise the device. thanks
May 19, 2008 | Maxtor (6B250S0) (6b250s0-20pk) 250 GB...
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
New Maxtor 3200
Hi, This is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the PS3200 itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 02, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard Drive Logo
83 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
