Dryer (part of washing machine) not working correctly
I have an AEG Lavamat Washer Dryer and whilst the washing machine cycle appears to work correctly this is not so with the tumble dryer part, it will work occasionally but more often than not it starts the action but then after say 10 minutes it will cease and the code E 10 shows. I cannot find my original handbook that came with the machine it is about 4 years old. I am nit sure about the model but it is a fully intregrated model and as I say a combined Washer/Dryer
Hoping this is something simple and I can fix myself and needless to say your assistance in guiding me would be most appreciative.
Yours
Nigel Davidson
  • 15,935 Answers
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
Jul 14, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Lavamat
have youlooked in your manual it should have some codes in trouble shooting that will help you sort out the problem. hope this helps.
Jun 01, 2007 | AEG Lavamat 12710 Front Load Washer /...
Washing Machines Logo
293 people viewed this question
Top Washing Machines Experts
