Question about Epson LQ-2180 Dot Matrix Printer
LQ 2180 What happens when the load/eject button doesnt work on LQ 2180 Epson printer.
  • 4 Answers
There is a problem in panel
u need to check panel cable if it is connected properly
if the prob. doesn't be ended then u need to use another panel
Posted on Feb 20, 2009
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
I have Epson LQ 2180. When Ever i load paper from rear tractor feeder it loads the paper and still shows the paper out LED. If i press Load/Eject button it only loads the paper not eject. I have cleaned...
Hi
My friend we have LQ2180 in our office, there i a lever in the right side of the printer that indicates when you print your document. Adjust to upward to print the document from rear tractor and to print from the front push the lever downward. Maybe you accidentally, push down the lever.
Any problem, just message me. Regards.
Jan 11, 2011 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 loading papar continuesly, and pause button is on.
Possible fault in the mother board, look like the loading control driver is faulty and is running off.
You might have to check the input of the motor drive to see if there is a signal from the mP or it is shorting to run.
Sep 30, 2010 | Epson LQ-2180 Dot Matrix Printer
How to check paper end sensor for epson lq 2180
have to remove all the covers and its located in the paper load tray at the back has a plastci trigger lever and operates the internal switch what happens is the lever wears off or breaks on the end but the switch does go bad itself
Jan 22, 2010 | Epson LQ-2180 Dot Matrix Printer
How to reset password of EPSON LQ-2180 printer
Printer can't have a password, maybe a network password you are referring to? I double checked in the manual for this printer and there is no way to set a password on the printer...
Jun 30, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Jan 09, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
235 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
