Question about Poulan Pro Chain Saw 46cc 20"
Poulan 46cc has very little power
Saw will start fine when givin gas it runs fine but when trying to cut saw boggs down the saw will cut but very little pressure can be applied,brand new chain
  • Anonymous Mar 16, 2014
    Brand new saw. Is not cutting, although blade rotating.
    Sergeant:
    Champion:
  • 239 Answers
You need to adjust the gas an air on those two little screws on the carburator
Posted on Feb 06, 2009
My polan saw will start but boggs when given gas if you pump the throttle it will run at full throttle buy once it idles down it stalls
This is fuel starvation, replace the fuel filter in the tank, check the fuel hose up to the carb for signs of leaks, or cracks, if the carb has no anti tamper screws, screw the L screw out 1/4 turn to richen the mixture, if the carb has anti tamper screws you will need to get the special tool to adjust them.
Sep 15, 2011 | Poulan Pro Chain Saw 46cc 20"
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Apr 25, 2011 | Poulan Pro Chain Saw 46cc 20"
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan p3416 .3 1/2 years old . gas cap has become really tight,from the first turn
Poulan.com
http://www.ordertree.com/modelinfo/PWE/P3416-Gas-Saw-Type-2/75.P3416-Gas-Saw-Type-2.1.59.1.html
Handle, Chassis, & Bar Assembly
Item 15, $3.09
Maybe a little cross threaded or swolen from contact with fuel.
Please verify this is your fuel cap. HTH
Lou
Oct 29, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a poulan pro trimmer, it wont stay running
First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
But first check the muffler.
Good luck
Aug 05, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan 330 22 inch
Check all bolts for tightness, especially the cylinder bolts. HOLD IT A SECOND did you add oil to the fuel?. If not you could damage engine very quickly. You have to have the proper mixture of oil and gas. Your owners manual should tell you the proper mixture.
Apr 11, 2009 | Poulan Pro Chain Saw 46cc 20"
POULAN PRO 295: RUNNING VERY STRONG, FOR OVER AN
Remove the air filter, squirt a little fuel into the carb. Start and let run if it will for a few minutes. Could be you had some water in old fuel. and it is still in the intake of saw. If it still will not run after squirting some fuel into carb. You have a firing problem.
Apr 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Runs bad like no fuel
well assuming this is your model:
getimage.php?m=pp4620avx&s=s&t=chainsaw
--> poulanpro.jpg&s=hs
Chain Saw PP4620AVX 952802146
  • 46cc 2-Cycle Gas Chain Saw
  • 20" steel bar
  • Anti-Vibe Handle
  • Automatic Chain Oiler
  • Super clean air filter system
  • Tool-less Chain Tightening System
  • 2 Year Warranty
I would go to Poulan Directly and Voice your Complaint with them, they might make it right with You...
You can Contact them at:
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1.800.554.6723
or Via email/request form:
http://www.poulan.com/poulanpro/contactUs.do
Good Luck!
Dec 13, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Chain Saw 46cc 20" Logo
194 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
