Question about Sony Cyber-shot DSC-W35 Digital Camera
DSC-W35 drivers/software download from internet
At the moment I'm abroad and don't have the camera software with me. I need to download photos from camera to pc, but the pc is not recognising the camera. The pc runs on windows xp. Can you please help?
  • tapnpar Feb 04, 2009
    my pc ask for sonypvu1.sys but i don no were can i get it please help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
You don't need any drivers or software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Posted on Nov 26, 2012
  • 39 Answers
SOURCE: Windows 98 Driver required for sony cyber-shot dsc-w35
Windows 98 is not officially supported by Sony for the DSC-W35. You can find hacked versions on the web but they may not be stable. You can find a list of supported Operating Systems here at the Sony website. http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCW35&LOC=3
I would suggest trying to use the Windows ME drivers. Windows ME was based on Windows 98 so the drivers for most applications are virtually identical. I have used 8 different drivers from other vendors in situations like this and it worked out fine. However, please be aware that since it is not officially supported it can cause interoperability options with your Windows 98 system.
This is the best suggestion I have. By no means should you get Windows ME, it was one of the worst versions of Windows released. Lots of bugs and there are less drivers for this operating system than your Windows 98.
Posted on Apr 28, 2008
SOURCE: HOW CAN I USE SONY DSC-W35 AS WEB CAM
my save this problem,and my sony DSC-W35 is not use to webcam
Posted on Mar 06, 2009
  • 17 Answers
SOURCE: Sony Cybershot DSC-W35 Camera doesn't detect the USB cable
You dont need the disc to download to computer.Take the card from the camera and put it into the card reader on your computer if one is fitted, if not you need one that goes into a USB slot When the card is inserted into the reader a box will open on the screen with several options as to view images or download them.
I would also download Picasa 3 which puts your photos in date order and also has photo editing. This is a free download and is part of google.
Dennis Darwin
Posted on Aug 01, 2009
welcomejee
  • 10594 Answers
SOURCE: When I turn on my Sony Cyber-shot DSC-W35 the
Its lens error in your DSC-W35 camera.
Lens mechanism is either stuck or not retract completely and system control sense this error. Please replace lens assembly to get it fixed because lens mechanism is not repairable.
Thanks.
Posted on Dec 20, 2009
  • 11967 Answers
SOURCE: SONY DSC-W35
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 05, 2010
I lost the software of the sony dsc-w35 camera. so now icannot take the photos from the camera to the computer. so what should i do? can i download the software free?
sony drivers should be included in XP, Vista, and 7 operating systems.
You can download the sony software, but in my experience with Sony, the drivers should be on the computer as a standard feature.
Try to connect the camera to the computer and see if it downloads the pictures without installing additional software.
Good luck on this.
Nov 12, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
Lost disc
DSC-W35 / 55 is plug and play camera, hook it with computer through USB cable, Windows will recognize it automatically and will install required drivers.
You will see Mass Storage device icon in My Computer, click it to see pictures of camera. No need of software cd installation, Windows has inbuilt drivers for this camera.
Thanks.
Apr 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When I turn on my Sony Cyber-shot DSC-W35 the screen is dark with the word "Access" on it, moments later it tells me to power it off adn on again, any ideas?
Thanks.
Dec 20, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I lost my sony cybershot dscw35 camers's cd. where can i get the softwar and driver
You can download the camera driver software here:
http://sony.driversdown.com/sony-drivers/Sony-DSC-W35-Cyber-shot-Cameras-Picture-Motion-Browser-Driver-Version-2.0-for-Windows-XP-2000-Vista_73892.shtml
Nov 20, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Dennis Darwin
Jul 30, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Sony Cyber-shot  DSC-W35 Digital Camera Logo
389 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
John Peabody
John Peabody
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
