Question about Samsung Digimax 4010 Digital Camera
Samsung 4010 camera wont accept a 4g sd card
When Itry to use my 4g sd card the green power light just flashes on/off and then I can't turn it off unless I lift the battery cover to power it down.
  • 1 more comment
  • Anonymous Feb 19, 2009
    8gb micro sdhc card in sd adapter cause causes green light to flash
  • Anonymous Mar 06, 2009
    when Itry to use my 4g sd card the green power light just flashes
    power it down.
  • xsdbs Mar 14, 2009
    foggy, thanks for your help,
    xsdbs
The camera will only accept true SD cards i.e. up to 2Gb. Your 4Gb card will be an SDHC which is not compatible. See here http://en.wikipedia.org/wiki/Sd_card#Compatibility_issues_with_2_GB_and_larger_cards for further explanation.
Posted on Mar 13, 2009
I have smasung digimax 4010, I have a 4gb memory card and when I put it in, the light flashes continuously and the Samsung logo is on the screen but thats all.What do I need to do???
You need to get an SD card. The 4010 works with SD and MMC cards. Your 4GB card is an SDHC card. While it fits into the slot it's electronically incompatible and will not work in the 4010. You need an SD card, 2GB and smaller.
Jul 28, 2012 | Samsung Digimax 4010 Digital Camera
I have a digimax 4010. Do I get a 2mg sd card? What is the diference between a sd card and a sdhc
SDHC is an extension of the SD standard that extends the capacity from 2GB to 32GB. It's backward compatible in that devices designed for SDHC cards will also work with SD cards. It does not go the other way---that is, SDHC cards will not work in devices designed for SD cards.
I presume you mean a 2GB card, since a 2MB card might hold one picture.
The Digimax 4010 works with SD cards, not SDHC cards. You may use an SD card. Just make sure it is an SD card, 2GB and smaller. SDHC cards start at 4GB and go up to 32GB but, as stated earlier, will not work in the 4010.
May 25, 2011 | Samsung Digimax 4010 Digital Camera
Myh polaroid pdc4350 wont accept a scan disk sdhc card 4g but will accept sd cards?
That is correct. While SDHC cards will fit into SD slots, they are electronically incompatible. SD cards will work in SDHC slots but not the other way around. You need to go with SD cards 2GB and smaller.
Mar 19, 2011 | Polaroid PhotoMax PDC 4350 Digital Camera
Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
May 11, 2010 | Samsung Digimax 4010 Digital Camera
Camera won't get past "Samsung" screen when mem. card is inserted
make sure there isn't a limit on the memory size for the camera, some models have a limit.
also make sure the lock switch on the memory card isn't in the locked position: http://kb.sandisk.com/app/answers/detail/a_id/1102
Dec 25, 2009 | Samsung Digimax 4010 Digital Camera
Lens not work
Should the green LED flash continiously - there are still life left in the camera. Insert an external SD memory card in the battery compartment and the camera might power on. Seems the internal memory of 16MB is faulty....
May 28, 2009 | Samsung Digimax 4010 Digital Camera
2gb memory card wont work in samsung digimax 4010 digital camera
this is an older unit, when this unit was manufactured, 2gb memory cards were still unavailable. basically, 2 gb memory cards are not compatible with the unit, try to use a lower capacity memory card
May 07, 2009 | Samsung Digimax 4010 Digital Camera
Wont turn on, power light just flashes and nothing happens
batteries are dead,or not in properly.if not. only use energizer lithium batteries.others burn out very fast,hope i was helpful.
Apr 14, 2009 | Samsung Digimax S500 Digital Camera
2G SD card will not format in Samsung Digimax 4010 camera
you cant use 2gb sd card with this camera. check the guranteed media capacity for your camera. check your manual.
Jan 15, 2009 | Samsung Digimax 4010 Digital Camera
Card locked
Reformat card - have you tried? Check your manual seek help in Samsung Web site Come back if still int rouble
May 06, 2007 | Samsung Digimax 4010 Digital Camera
Samsung Digimax 4010 Digital Camera Logo
195 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
