Question about Emerson iTone iC200 Clock Radio
Ipod touch 2g doesn't charge or play music
It plugs in fine, but no response from the ipod.
  • Anonymous May 02, 2009
    Problem Solver:
  • 6 Answers
Take it back to an apple store, is should be under warranty so it'll be fixed for free
Posted on Nov 03, 2009
Altec lansing connect
IM600 Compatibility: iPod mini; iPod classic 3G, 4G, 5G, 5.5G, 6G; iPod nano 1G, 2G, 3G, 4G; iPod touch 1G, 2G; auxiliary input connects to any CD, DVD, or MP3 player using a stereo mini-plug. If you have a mini-plug port on the IPhone which I believe you have; then attach a male to male plug in between the two devices. Take to Radio Shack for correct line plug.
Feb 09, 2014 | Altec Lansing Technologies Audio Players &...
Sony ICF-DS11iP doesn't play my Ipod touch. Radio, Alarm, Ipod Charging functions work. Pls suggest a solution
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
Sep 03, 2011 | Sony ICF-C1IP (Black) Docking Station
My ipod touch will not charge on my Zepplin, it did until recently but now it says it doesn't support charging
happened on mine, just try cleaning out the dock on the speaker and in your ipod and move the plug socket, hope this helps :)
Aug 09, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
My ipod touch wont play music on my docking station it used to it still charges it help
I had this problem too. You're going to have to restore it with iTunes.
  1. Plug your iPod into your computer and sync it with iTunes.
  2. Go to the "Summary" tab and choose restore.
  3. Let iTunes do its thing and try it on you dock again.
If that doesn't work then I would suggest taking it on and off of the docking station until it works. I know this sounds really primitive but this is what I ended up doing and now it works fine.
One last thing, if you recently upgraded your iPod's firmware then that might be what is messing you up. Sometimes docks aren't compatible with the newer firmware Apple puts out so you might have to buy a new dock unfortunately. But if your iPod was jailbroken on a past firmware you can use this video to downgrade it to when it worked with your dock.
Apr 09, 2011 | Apple iPod touch
When I plug in my Ipod to the inMotion im310 portable speaker the Ipod screen says it is not supported, and it worked this morning.
Check the pins on the speaker and on the plugin on the iPod, that's the problem usually. Also, check if the iPod is truly compatible, even if it worked before it may not be. I have seen car chargers for say a 2G iPhone work for a bit then say incompatible, it happens. Here are the compatible iPods for the iM310:
Plays and charges
iPod mini;
iPod touch 1G, 2G
Apr 10, 2010 | Altec Lansing inMotion iM310 Portable...
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 :
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
My Ipod touch won't charge, it plays music
I bought this Charge Converter from CableJive. It allows me to charge my iPhone 3g on many accessories that would not normally charge the newer models and has successfully fixed the issue with my H+K Dock. I definitely recommend checking them out.
May 11, 2009 | Audio Players & Recorders
I cant get my ipod nano 2g`s speakers to work when docked?
i tried it again and it didnt work so i went back to argos and got another one and it worked then it was my 1st ipod it was faulty lol
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
Ipod touch 2g home key unresponsive
Hold the power botton and Home botton at the same time it will reboot and should work fine.
Mar 23, 2009 | Apple iPod touch
Emerson iTone iC200 Clock Radio Logo
593 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
