Question about Technics SL-1210 Turntable
Turntable Crackling Basically, my problem is one which has been on and off for a while now. I have a Vestax VMC-185XL mixer connected to my turntables (also with Serato connected). My problem is whenever I use the crossfader to scratch or to just fade, it makes a horrible crackling sound as I move the fader. I guessed the problem was static, so I cleaned the fader using some DeoxIT Fader Lube. This hasn't helped. I have realised that the problem only occurs when the needle is on either of the turntables, whether the vinyl is spinning or stopped. I also tried buying new needles to see if that helped...no difference (I use SHURE M44-7 carts), taking off the tone arm and blowing on it for dust didn't help on either side and I tried the obvious of just giving my vinyl a good clean. I cannot find a resolution to this problem. The crackling seems to fade away if I take the needles off the record while sliding the fader. So this seems strange to me. I checked the earthing wires on both decks, both are properly attached to the back of the mixer... What is going on?!!! I have a party to do on the 14th and if I use my mixer and turntables the way it sounds at the moment...the crackling won't be bearable! Many thanks in advance, Nathan Wickett
  • naff47 Feb 12, 2009
    Thanks for the help Jon. That was kinda what I expected. I think it's a bit annoying though seeing as my Vestax is supposed to be a scratch mixer. I've only had it a year.
    Thanks again, time to buy a new fader (a new mixer is too expensive for now. haha).
    Problem Solver:
  • 17 Answers
Sounds to me like your fader has popped! lube contact spray will not solve the problem, it will only clear it up for a few passes if any! PCV faders have covers inside which stop any lube getting right on the contacts! but in my experience as a scratch dj for 11 years is that contact spray only make the problem worse over time! best shot from here is to replace the fader, or get a mixer with optical/contactless fader i suggest a mixer with the 'eternal' fader i.e. ecler 360/80hak. hope this helps
Posted on Feb 11, 2009
Humming with vestax
hummm , does it also hum with the other gear shift out, especially tl and ledlights, if so it't a ground loop, but often is just the earth of the turntable not well connected
Apr 14, 2014 | Vestax Handy Trax Turntable
Why won't my vestax vmc 002 turn on
Try replacing the fuse by one with same voltage and rating. Usually if you take a look at paperwork that came with the mixer it will show you which fuse you should use.
Jan 05, 2013 | Vestax Vmc - 002 Xl
How do i replace faders for the vmc 004
Hi you will have to open the mixer, make sure the power cord is not plugged in. The fader screws in from the back and the wires may be soldered. so you will have to unsolder the wires and re solder them to the new fader and replace and screw new fader in. Close mixer ..
Jan 31, 2010 | Vestax Vmc004 4-Channel DJ Mixer System
The headphone jacks on my mixer(Vestax PMC-06 Pro A)not working
did you try the headphone jack in the back? also is the cue fader crackling when you move it left and right? also check if the cue fader is plugged in. if none of the above, check with your warranty
Apr 14, 2009 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
I have a Stanton T.80 and Vestax VMC-185XL mixer. I recently bought Rane Serato Scratch Live which requires the turntables to be grounded through the mixer...however, the turntable doesnt have a ground...
Hi gium
Sounds like we have reached that point where progressive crossover in technologies means that the usual cautions of earth continuity for the tone arm when using a phono preamp has gone the same way as phono preamps on home theatre.
Have you tried switching to the line level and set the mixer up for that level also. That may reduce any gain induced hum. However it sounds like an earth loop problem, where both decks will need to be earthed in the mixer. Check also that all the gear is running of the same power point. Different mains phases are sometimes available near each other, having any gear (power amps also) on a different phase will cause an earth loop problem.
Is the hum all the time independent of the volume levels, or change with levels adjustments and not at all when turned right down. Let me if changing to line levels helps. We can try some more things, like connecting a temp hookup wire earth to the RCA earth to mixer chassis. Cheers
regards
robotek
Oct 04, 2008 | Audio Players & Recorders
Samsung HLN5065W freezes in black / White screen
Picture freezing that is the symtoms of depected DMD modules...
Just click below for electronics store you can order online;
Partstore.com.
Vance Baldwin Electronics
http://servicemanuals.vstore.ca/
http://www.electronix.com/catalog/
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung HLN5065W 50" Rear Projection...
Vestax PMC 05 PRO MIXER master output is not working
More than likely the output PCB might be faulty, or the signal amp might be damaged. In either case, not an easy fix. As for service in the UK, try HARD TO FIND RECORDS - they have a pretty good service dept.
- OPTiC
DJ Pro Audio
www.djproaudio.com
www.1200s.com
www.repairnyc.com
Jul 25, 2008 | Vestax CDX-05 Turntable
Low volume on both sides
Make sure you connected the turntable to the PHONO INPUT of your Vestax Mixer. If so, then the problem might be with your mixer output, or your sound system. You will need to test each unit individually to determine what the issue might be.
- OPTiC
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 20, 2008 | Technics SL-1200M3D Turntable
Technics SL-1210 Turntable Logo
669 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
