Question about T-Mobile Sidekick® 3 Cellular Phone
Wont work after being droppped
I dropped my sidekick3 ... it started to charge and worked for a minuted then shut off now wont work at all
    President:
  • 625 Answers
Pull your battery and let it sit for a few hours.
Posted on Feb 05, 2009
I droppped my external hd its a maxtor4 one touch and wont turnon
You have dropped and subjected the HDD to such a shock that most likely its head has got bent and stuck. Can you believe that a small peck of dust in the path of the read/wrote head is like a big box lying in front of you. And when subjected to such a shock, the head may have got bent and got stuck. The HDD is a goner as doing it up would take more effort and money that buying a new one. As regards the data on it, now, only a professional would be able to recover.
Dec 02, 2009 | Computers & Internet
I got a Samsung Gravity and it wont turn on.
dear,
if your phone dropped in water then the first step to be done is immigately remove the battery and then let it dried through a table lamp. you should keep it under 100 W test lamp at a distance of 5-6 feet. if it worked fine after dropping in water and again shut off then open the cover and do this method..
goodluck....
Aug 20, 2009 | LG VX5200 Cellular Phone
2007 mercury milan V6 Car wont start. Jumped it
Remove the lugs at the battery. Clean the posts and the lugs - then reconnect. Your battery won't charge (and the jumpers won't work) largely because of a film on the + post and lug. If you live in a hot summer area, (Arizona) the problem is especially troublesome.
Jul 15, 2009 | 2007 Mercury Milan V6 AWD Sedan
Tmobile sidekick3 wont charge
It's called the sidekick 3 charging port and they are known to go bad a lot.
You can check out cellulardr for the repair. It runs about 75 dollars or you can get a external battery charger cradel and charge the battery outside the phone.
Feb 17, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Lights Dim, Radio shuts off, battery gauge dropps
I would check the ignition switch, they are know for separating and causing issue's like this one, Ford recalled many of them, but the Explorer was not on the list, though it uses the same switch as the recalled cars..
Jan 21, 2009 | 1999 Ford Explorer
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3 got wet
those kind of problems are fixed by totally changing the parts... because nano technology is very hard to fix..
you could also try opening it and clean a bit the outside of the lens and see if that helps.. but i doubt it because it could be or will be a sulfated contact
Nov 04, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
A sidekick3 that dont power on
well the same thing happen to me but i call t-mobile and they tell me to press @ 1 and 0 at the same time and it should reset it self it doesn't work for me but you can try it
Mar 20, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick® 3 Cellular Phone Logo
46 people viewed this question
Top T-Mobile Cell Phones Experts
Thomas Perkins
Thomas Perkins
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
