Question about Hotpoint FFA70 Bottom Freezer Refrigerator
I have an FFA70 fridge feezer thw fridge does not drain propery
There i swater in the bottome of the fridge as the ole overflows 0
  • canev_mansfi Feb 03, 2009
    thanks looking at the fridge from the back is it on the right hand side?
    Problem Solver:
  • 12 Answers
Turn fridge around at bottom you will c a round black cooling pot the fridge overflow pipe leads to here so water can drip on it and evaporate with the heat from it take off pipe give it a blow to remove foreign objects it should sort problem
Posted on Feb 03, 2009
Frezzer door left open all contence ruined red light what do I do now
defrost and clean out the freezer and refrigerator (empty completely). , unplug. turn the temperature selector to 0 . plug back in turn the selector to the preferred temperature and it should work again. Do not forget to also clean the surplus water collector in the back of the fridge if its full.
Jul 01, 2014 | Hotpoint FFA70 Bottom Freezer Refrigerator
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water dripping to form puddle at bottom of fridge cabinet (upper, above freezer) on FFA70.Why is this, how can it be stopped?Thanks
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 10, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
My Hotpoint FFa70 - Fridge acting like a freezer!! Freezer ok!!!!
Check your settings. Each compartment has its own and lower settings to at least the half way point from highest.
Jul 02, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70
This will work in most all cases of this type. You need a piece of copper wire, 14 guage, 12 to 16 inches. You can shortin it as you need to Turnoff the power to the fridge. Rap one end of the wire around the evaprorator heater and feed the othe end down the drain tube. This wire will heat up when the heater comes on and will supply heat down into the drain tube hopefully preventing the drain from freezing.
Nov 19, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint FFA70 Bottom Freezer Refrigerator Logo
174 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
