Question about Archos AV 500 400-Hours Video Recorder
No signal on my goodmans xpro freeview on the flat screen it says
I can not get a signal on my goodmans x pro freeview ,on the flat screen it says no signal ,hope i have got it connected properley,someone please help,
  • 2 more comments
  • trevor_russe Feb 06, 2009
    thanks very much for this,i will try this,also could you tell me where i connect the lt lead,do i have to loop it from the freeview box to the portable tele,,as the freeview is only connected to a monitor,once again thanks,trev
  • trevor_russe Feb 07, 2009
    have bought a freeview aerial will try that once again thanks very much
  • andyinalaska Mar 25, 2009
    i have a new portable flat screen hitachi tv and it worked fine when the ariel was plugged into the house ariel socket but now the tv is upstairs it keeps saying no signal now that i am using a portable ariel. The ariel is brand new too and is a 45db ariel for digital tv.
  • Porc2 Apr 25, 2010
    i am asking the same question more than a year later. is there know expert out there to give an honest and accurate answer?? grrrr
    Sniper:
  • 57 Answers
Hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
http://www.freeview.co.uk/availability
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Posted on Feb 06, 2009
  • craig pursloe
    craig pursloe Feb 06, 2009
    hi there yeah use a portable this will be fine goo luck M8
  • craig pursloe
    craig pursloe Feb 07, 2009
    Thanks Im Glad I was Able To Sort This Problem out for you Good Luck And Remeber were always here At FixYA
    Thanks DirtyDozenUk
Fuse keeps blowing on power board. It is the 3.15 amp fuse on the goodmans xpro tv
Most likely you have a short on the front side of your power supply. You will either need to have it repaired or replaced!
Oct 22, 2012 | Goodmans GTVL32W27HDF 32 in. LCD TV
I cannot get a fachi universal remote to work anything
THE THREE DIDIT CODE FOR A GOODMANS XPRO DVD RECORDER GDVD301R .FOR MY FACHI UNIVERSAL REMOTE
Jan 17, 2011 | Televison & Video
Need a manual for Goodmans XPRO GHC 304 DVD Recorder
Please try these links and post your requirement of the model;
www.devicemanuals.com/guide/???DVD-manuals.html
www.tv.manualsonline.com/???manuals/device/???dvd_???player.html
Sep 30, 2010 | Televison & Video
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Goodmans Xpro GPDR40
I NEED DRIVERS FOR DPDR 40 X-PRO
Jan 05, 2009 | Goodmans GPDR40 Digital Media Player
Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Oct 15, 2008 | Goodmans W280NS Television
Archos AV 500 400-Hours Video Recorder Logo
701 people viewed this question
Top Archos Televison & Video Experts
Henry  Thomas
Henry Thomas
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
