Question about AT&T Lucent MLS-12D Phone
Voice mail Need to know how to change a call coming in to ring 2 times instead of three when going to voice mail?
    President:
  • AT&T Master
  • 860 Answers
Depending on the type and version of your partner system the procedure should be as follows:
1) from either ext 10 or 11 press the feature key and 00 on the dialpad
2) press the left hand intercom twice
the display should say system programming
3) dial "#506"
the display should say vms hunt delay
4) enter either 1 for day ringing assignment or 2 for night ring
5) dial the 2 digit line number i.e. line 1 is 01...
the display should say the ammount of rings previously programmed (3 Rings)
6) dial "2" on the dial pad
repeat the steps from number 3 on for the rest of the lines
7) press feature 00 whem finished
hope this helps.
Posted on Feb 10, 2009
Voice Mail Pick up
Changing the vms hunt delay on a Partner ACS system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
enter in "#505"
the display should say VMS Hunt Delay and mode:
enter 1 for day mode or 2 for night mode
enter line you want to program in 2 digit format (line 1 =01)
enter number of rings (2)
press feature "00" to logout
May 02, 2013 | Avaya Lucent / Partner 206ec Expansion...
Can I change the ring count for voice mail to three instead of 2 or 4 OR6
Sorry you cannot set ring count for voice mail to 3.
It has settings to set for 2,4 and 6.
Thanx
Jul 04, 2010 | Uniden TRU8885 Digital Answering Machine
How do I send a call to internal voice mail?
Use feature 986 (transfer to VM) then enter in the co-workers extension number. That will bypass the extension and send the caller directly to his voicemail.
Jun 29, 2010 | NorStar M7324 Telephone
Fax call goes to voice mail not to fax machine
Press dataregistration,press arrow up or down untill RX settings is display press start,press arrows untill incomming ring is displayed press start,set to on,next the amount of rings will apear on screen,change it there to the amount of rings.
Jan 14, 2009 | Canon FAX-JX200
Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
Nov 19, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Change the amount of times it rings before goes to V-mail
In Coverage path form for voice mail
COVERAGE CRITERIA
Don't Answer? y y Number of Rings: 2
COVERAGE POINTS
Point1: h2 Rng: 1
you can change Number of rings,Rng options
Jan 17, 2008 | NorStar T7316E Corded Phone
Phone Doesn't Ring Long Enough Before Going To VM
The phone you have can be used on different Avaya phone systems that program differently. It is certainly something that can be changed but you would need to know which system you have first. There is a call-forward no answer timer that send the call to another station or voice mail box etc.. after so many seconds. That is what needs to be changed.
All the manuals are available at www.avaya.com but again, you would need to know which system you have before looking for the manual.
Nov 15, 2007 | Lucent PARTNER18 Corded Phone
It rings 20 times before voice mail comes on and they can leave a msg.
You are asking questions about your Toshiba phone system and the voice mail system attached. You could have one of several different Toshiba phone systems and several different voice mails.
The system has timers for things like "No answer transfer timer" and also rules for what it does at that point. (transfer to voice mail box, transfer to voice mail branch, transfer to the operator.. etc..) It can get very complicated. Most likely you are just dealing with the no answer transfer timer for your specific phone port but even just changing that can be very complicated. Many Toshiba phone systems need to be programmed from a computer using specific software. If you do not have someone in the company that knows how to make simple changes to the phone system you would need to get a phone system installation company to make the changes. Hopefully you know the company that installed the system??
Nov 09, 2007 | Toshiba DKT-2010 Corded Phone
Going to voicemail
The phone you have can go on several different Norstar phone systems and you can have several different types of voice mail. Your voice mail (and possibly the phone system) needs to have programming changes, not the telephone. Your first step is to determine which Nortel phone system you have and also what model voice mail. You will need manuals for the phone system and voice mail. Hopefully you already have a programming or administration manual for the voice mail. Someone should have gotten this information when the system was first installed but that could have been many years ago.
What happens when you are waiting for that time? Do you hear absolutely nothing? Instead of being sent directly to your voice mail box, it may be sending callers to a voice mail branch where you would normally have a recording "press 1 for this, 2 for that" If there is no recording the system will wait for a response that the caller has no idea of and usually replay the message 3 times before defaulting to your mailbox (in this case a blank message). That is my best guess with the information I have from you so far.
Nov 01, 2007 | NorStar T7316E Corded Phone
AT&T Lucent MLS-12D Phone Logo
181 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
