Question about Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater...
Takes long time to heat then goes from hot to cold.
It is a Bosh AquaStar2400E-NG tankless hot water heater about a year old.
  • 34 Answers
I know that this is a great answer but with out being there its hard to answer you call there tech support they are great, I have had to call they from jobs before they can help
Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
Posted on Feb 04, 2009
On demand hot water heater gets cold for a short while during showers.
Check for crossover.
Bad single-handle faucet cartridge causes cold water to enter hot pipe, so hot never arrives and tankless does not run consistAntly
http://waterheatertimer.org/Crossover.html
Apr 13, 2013 | Bosch AquaStar 2400ES-NG
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
We have a customer that has a 751od who says at times thier water gets cold for a few seconds. No error codes on the remote. They claim it does it at different fixtures. Everything checks out from water...
A few things you should check:
1. Cross Connections - this occurs when cold water leaks into the hot water system through a fixture. In order to check for a cross connection: 1) turn off the cold water to the tankless 2) open up hot water fixtures in the home. The water should shut off at all hot water fixtures; if there is a continuous flow of cold water, then you have a cross connection. The most common place to find a cross connection is on old shower cartridges.
2. Ask the customer to check to see if the burner indicator is continuously lit during operation.
3. When the water goes cold at one fixture, try another near by fixture to confirm it is also cold there. If its hot at one fixture but not the other, then you have some issue with you plumbing. Tankless heaters can't pick and choose which fixtures to deliver hot water to.
4. Tankless water heaters all have a minimum flow rate that must be maintained in order to continually fire (.5 gpm for Noritz). Ensure their hot water fixtures flow at least this amount, or that the customer isn't mixing too little hot water at their fixture.
5. If they see the cold spurt during initial firing, they may be experiencing a cold water sandwich. When the heater moves from a standing state to a firing state it takes a short period to ignite and heat water. During this time it will be passing cold water through the system. Usually this cold water mixes with hot water in the line as it travels through the plumbing system, but if their fixture is very close to the heater, there won't be enough time to mix.
6. If debris has gotten into the flow sensor, this can prevent the unit from registering flow and cause intermittent firing.
Aug 27, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Water will not stay hot
The cold main water pressure is too low to maintain a constant flow. Make sure you have no other appliences on, or your not comprimised by the lowering of pressure
Jul 23, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch tankless GWH 1600 H NG won't always ignite. The igniter sparks, but doesn't always light the gas. It just clicks. When installed it lit every time, now it takes more and more tries to get it to...
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
Mar 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Hot and cold water from tankless heater
check your tigh/low water temperture setting. you may have them crossed.
check all of your wiring.
Jan 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Just not hot enough
Hi Ken Tankless Water Heaters typically heat to a 80 deg temp. rise. Per a set time it takes the water to pass through the heat exchanger. Matter of seconds So at 130 deg F. Your heater is working fine. Did you take a heat measurement or are you looking at the set points inside the cabinet? To get the 130 deg F you need to upgrade the sensor available from your Bosch Dealer. Typical output water temperature would be 110. There are scalding issues over this set point. As long as you have 3/4 id pipe in and out and have insulation on the discharge side of the heater at all exposed points of the pipe. Your system was likly installed properly. Look it is only my opinion but Bosch it the best you can get in Tankless heaters. As for the dishes. Use the sanitize setting on the dishwasher or alittle extra bleach in the dishwater. And don't forget to rince with fresh water only. For the shower or tub. Use less cold water in the mix. Tankless water heaters were designed to use less resorces aswell as energy. And I want to thank you for that.
Jan 05, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Logo
229 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
