Question about Video Game Consoles & Games
Cannot run Professor Tim's Incredible Machines on my pc
My pc is running Windows xp. The pc game was originally designed for Windows 95.
I have tried ignoring the initial prompt to install which was unsuccessful and copying all the files into a backup folder on my C drive. I right-clicked the TIMWIN.exe in the back up version, chose Properties and set them for Windows 95 and 256 colours. I then went through the normal install process without running a system test which had caused problems before and ignored the notification of failed tests and it seemed to install ok. Then when I go to play I get a Windows error report.
  • Ron
    Ron May 11, 2010
    could you please provide the error details and description?
  • 51 Answers
Try running the setup file and game in compatability mode for Windows 98. It should cure it. It is likely that the software does not recognise the hardware on your computer though, and if this is the case the software won't run at all.
Posted on Feb 13, 2009
I would like to run learn to speak english (setup file version 2.0.71.0) under Windows XP. How can I do that. Previously it was run under windows 95. TAhn you in advance
Hi, welcome to FixYa.
Windows XP provides such compatibility mode to run old program in Windows XP. Believe me, I've tried this and it works, in my case I installed my old game The Lost Mind of Dr Brain which developed for Windows 3.11 or Windows 95.
To do it, you just need to locate executable file of your program. Then right click on it, choose Properties. Then go to Compatibility tab, checked "Run this program in compatibility mode for:", then choose Windows 95. You may also need to thick the "Run in 256 color" and "Disable visual themes" check box.
I hope this can help you out. Thanks for visiting FixYa.
Mar 14, 2011 | The Learning Company Learn To Speak...
Hello, my game earthworm1-2 dont work my computer say that this game incompatibiliteit is with the 64 bits version from windows i have an asus laptop 1/2 year old with windows 7 version wath can i do to...
Hi, phoogland!
Older products aren't compatible with newer OS. The best way you can play these games is probably by emulating a virtual PC. Try installing Windows 98 on a Windows Virtual PC.
Here's a link to a detailed manual: http://www.essjae.com/virtualization/WinVPC-InstallingWin98.pdf
If this didn't fix your issue please let me know. Hope this helped you!
-Luchen
Mar 07, 2011 | Activision Earthworm Jim for Windows
I have windows 7 installed on my pc.i installed cossacks II napoleonic wars properly,and when i try to start the game,i get information that the game can run only on older versions on windows (95,98 XP )....
Well, try this, we call this "compatibility" mode, most programs can be run on windows 7 with this trick.
I assume your Cossacks II Napoleonic Wars icon is on the Desktop,
Right-click the Icon (game's icon), select "Properties" and click "Compatibility" tab, select "Run this program in compatibility mode for" click the "Windows 95..." and select "Windows Xp (Service pack 2)", click "Apply" > "Ok" and try again.
If even after doing this, the game can't be played, then there's no option. The fact is that, this game is made to run on system with Windows xp and earlier version, but somehow if fortunate, it's possible, not will all software, some may work, some may not.
Good luck.
Thanks for using FixYa.
Aug 12, 2010 | CDV Software Cossacks 2: Napoleonic Wars...
My Great Brain Robbery is old and says it works with Windows 95, Windows 3.1 & MacIntosh. I have Windows XP and can't seem to get it to setup. Any ideas?
1. Create a shortcut on the desktop for the setup/install program on the CD. 2. Right click in the shortcut you have created and select properties then click on the compatibility TAB at the top of the dialogue box. Tick the [Run this program in compatibility mode for] box and select windows 95. Then click [OK]. 3. Double click the Shortcut you just created and the program will install. 4. After it has finished installing find the shortcut it has created for the game and repeat step 2 for this new shortcut. It should now run in windows 95 mode.
Jan 09, 2010 | Davidson Pre-Algebra Math Blaster Mystery...
My game won't open, it says "New GFXSurface failed...get tech support..."
for some old games you usually need some kind of emulator, basically this will allow you to run a game in an environment the game was designed for.
out on a limb here but i assume usage of windows vista.
http://www.subsowespac.org/silent-hunter-windows-vista-dosbox.shtml
may help you
Apr 18, 2009 | Computers & Internet
This version of Windows does not support this version of Roxio DLA. This product, which was created by Roxio, Inc., has been blocked from running because it might keep your computer from starting correctly...
Getting older programs to run on Windows XP Getting older programs to run on Windows XP Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. To run your program on Windows XP, try the following:
  1. Run the Program Compatibility Wizard. As an alternative, you can set the compatibility properties manually.
  2. Update your program, drivers, or hardware.
These options are covered in detail below.
The Program Compatibility Wizard This wizard prompts you to test your program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows 95, set the compatibility mode to Windows 95 and try running your program again. If successful, the program will start in that mode each time. The wizard also allows you to try different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
If compatibility problems prevent you from installing a program on Windows XP, run the Program Compatibility Wizard on the setup file for the program. The file might be called Setup.exe or something similar, and is probably located on the Installation disc for the program.
To run the Program Compatibility Wizard
  1. Start the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
Dec 19, 2008 | Computers & Internet
SECURITY
Just an idea, but have you tried running the software in Windows 95 or 98 Compatability mode??
Right click on program icon scroll down to propertys CLICK,...
This should open a box with several tabs on the top.... click tab that says COMPATIBILITY and Check the box that say RUN PROGRAM COMPATABLE with windows 95 or Windowns 98.
Click OK and try the program again.
Just a suggestion, but it MIGHT work. Work a try,
Good Luck,
Sep 28, 2008 | Brother SE-270D Computerized Sewing...
I have a hard drive with windows 95 and i am trying to install windows xp professional addition but it comes back saying you can't intall this version of windows on this system
Windows 95 uses the FAT 32 system and uses a boot-up partition that will not recognize a windows xp default system install that uses the NTFS system. You can do it the other way around though, if XP is installed first, or another drive you have with XP on it is the first drive set to boot in your BIOS XP will recognize WIN 95 on its FAT 32 partition and either let you boot from that partition when you first start up your computer or when in XP right clicking a WIN 95 application and setting its properties to run as a Win 95 environment. Solution I would use if I were you would be to download Microsoft's free Virtual PC application from their website and run a full version of WIN 95 in its own virtual environment. Win 95 will run about 10 times faster than it ever would on its own partion if run under XP.
Aug 26, 2008 | Computers & Internet
DISC SPACE
The problem may be that you have too much space (sounds dumb I know) Windows 95/98 originally did not support drives as big as we have now, resize your drive down to less than 2GB and retry the install, or create a partition for the Game that si smaller. If you are running XP/Vista, you may be able to resize with disk Management, otherwise there is third party software like Partition Magic...
I hope this helped.
Dec 06, 2007 | Computers & Internet
Video Game Consoles & Games Logo
417 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
