Question about RCA CC6263 Camcorder
Tape tangles Hi, The tape tangles up in my RCA CC6263 VHS-C AutoShot Camcorder. How can I fix it. Thank you Elma
mistersony
  • 320 Answers
SOURCE: need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Posted on Oct 29, 2008
  • 4 Answers
SOURCE: How do I copy from JVC GZ-MG365BU Camcorder to a VHS Tape? How do
ditch the VHS recorder. Burn them onto DVD. It's the 21st century.
Posted on Feb 24, 2009
farr64
  • 121 Answers
SOURCE: What size tape is used for a jvc compact vhs camcorder model no.
ask for a standard vhs c tape
Posted on Apr 30, 2009
techman007
  • 1112 Answers
SOURCE: camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
mybradley7
  • 242 Answers
SOURCE: Tape stuck in Camcorder
check the tip in my profile
Posted on Jul 17, 2010
What kind of charger do I need for RCA autoshot 72x camcorder
suggest you contact the manufacturer thru their website customer support
Apr 10, 2015 | RCA Video Cameras
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
CLASSIC RCA AUTOSHOT VHS CAMCORDER.(DSP3) PROBLEMS
The vhs camcorder has very complex mechanics and hold many traps for the inexperienced.
I suggest you begin by obtaining a standard vhs recorder and remove the cover to expose the interior and then study it. You will find the engineering and interior geography of your camcorder similar.
The round shiny barrel-shaped thing contains the record and playback video heads and the sound head is separate and looks like a larger version of what can be seen in a standard audio cassette recorder.
The interior must be extremely clean, the drive belts in good condition and the clutches and rubber rollers also in good order.
Nov 16, 2017 | RCA CC6151 Camcorder
Conversion vhs to dvd
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Mar 26, 2010 | Video Cameras
Camcorder won't record
Dec 27, 2009 | RCA CC6363 Camcorder
Tape will not eject may be in wrong how do i get it out manually
Open up the door and push the tape in hard and fast. Hopefully it will popup a little to remove it.
Is this an old cassette? If its damaged in any way, or it's been exposed to moisture or extreme heat, it can cause the tape to jam.
If that doesn't work and knowing that this Camcorder has no repairable parts inside, remove the door and turn the load gears in reverse. If this doesn't work, you might need to pry it out. I still have my ancient VHS recorder and had to do that once about 13 years ago. lol
It still works, but I bought new tapes. I'm not sure if those tapes are still available but you could search online for those.
I hope this works!
ps. Just in case you've lost the original User Manual I've attached a link below!
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000029241.pdf
Oct 25, 2009 | RCA CC6263 Camcorder
Accidently recorded over important material on a vhs tape. Is there anyway I can retrieve it??
I'm afraid not. When you record, the record heads automatically erase everything that was previously on that tape. So whatever footage was on that tape is gone for good. Sorry!
May 29, 2009 | JVC GR-SXM750 S-VHS-C Analog Camcorder
Need unit to put tape into, to play in vcr
Oct 29, 2008 | RCA CC6263 Camcorder
Tape end camcorder
Have you tried different VHS tapes? If your VHS tape is too far rewound or at the very end your camcorder will display this problem. In a different VHS machine make sur the tape is rewound and then play the tape about a minute and then try it in the VCR.
If this doesn't work then there is a problem with the tape end sensors in your VCR.
Oct 04, 2008 | Video Cameras
RCA CC6263 Camcorder Logo
41 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
