Question about SanDisk Sansa e260 MP3 Player
Sansa e280r "not enough space for music db. please free 6mb."
I stopped my sansa mp3 player while it was being formatted now it says "not enough space for music db. please free 6mb." How do i get my mp3 player ready for use again? Also my mp3 player isn't recognized by the computer exept by 16 mb something, as a drive.
  • Anonymous Nov 29, 2007
    I have a SanDisk 150 that shows me the message. Not enough space for music db please free 6mb.
Do anyone know what to do with a E270 ?
same probleme here, but i can't get the steps above to work :(
I miss my music!!
Posted on Dec 25, 2007
    Problem Solver:
  • 10 Answers
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
Posted on Dec 01, 2007
I had the same issue. Plug the player in your PC. Go to "my computer" right click the Sansa player. Go to Properties and then select the "tools" tab. Run the error check and the disc defragmentation
Posted on Apr 20, 2008
SOURCE:
When i turn the player on it says Not enough space for music DB Please free 6 MB. But it says in the info Memory 0MB and Free 0MB
Connect to your computer copy music to a folder and save as whatever name you give it Then format Check the folder with the music in it to see if there is a file thats not MP3 delete it if there is one then replace the musicto the sansa keep about 6MB of free space
Dec 23, 2010 | SanDisk Sansa e260 MP3 Player
When turning on my sansa e250, the msg "Refresh Database" and "Not enough space for music DB. Please free 6MB" display on the screen. How do I do that?
Remove the microSD card, then connect the player to your computer and delete stuff from its internal memory until you have 6MB free.
Jan 26, 2010 | SanDisk Sansa e250 MP3 Player
Not enough space?
Format the player from the Sansa itself - directions are in the manual - and reload songs onto the player.
Jan 02, 2009 | SanDisk Sansa e250 MP3 Player
Says not enough space when there is nothing in the mp3.
just format it then put all music in again or just sync
Nov 10, 2008 | SanDisk Sansa e250 MP3 Player
Sansa
Reformat the player - see my "tips and tricks" on how to format an mp3 player for details
Jun 07, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
make sure the mode of the player is in MTP or if you have a version 2 player the default mode is MTP. If you are receiving an error about "Not Enough Space for Music DB please free 6mb" when turning on the player. Format the player using windows explorer and the mode should be in MSC.
Dec 07, 2007 | SanDisk Sansa e250 MP3 Player
PLEASE HELP I CAN"T LIVE WITH OUT MY SANSA
"Please free 6MB for music DB" means that there is not enough MEMORY for the MUSIC DataBase. Therefore, you cannot see the music on your device.
To resolve this, you need to delete music until your device is less than 6MB of being full.
Generally 10 to 15 songs should do the trick.
Best of Luck,
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
My sansa wouldn't work
The device needs 6MB free for each GB of music.
Delete about 10 or 15 songs and you should be all set.
Best of Luck.
Oct 30, 2007 | SanDisk Sansa e200 MP3 Player
My sansa is messed up
It is referring to the "database", or the menus on the device. (i.e. - songs titles, music, artists) It needs at least 6MB of free space on the device to create this. If you freed up what you think is 6MB, it may not be enough. Even though you have a 2GB player, there is only 1.85 of usable space on it. So try deleting some more tracks. If not, format the device and start over. Right click on the device in My Computer and select format. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
477 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
