Question about Maytag Neptune MAH5500B Front Load Washer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
Maytag Neptune MD5500AWW front load dryer - (purchased 2001) - propane
Heating works only for 5 minutes at beginning of cycle, sometimes more, sometimes less, sometimes it cycles a couple of times but not enough to dry clothes. Similar problem whether using timed dry or sense dry. Checked and cleaned exhaust vent - no problems or blockage.
If we run timed dry for 10 minutes, turn off, run again, and repeat we can get the clothes dry by using multiple cycles. But burner will not cycle throughout a complete dryer run - only the first few minutes of the cycle.
Thanks
  • Russ Walicki Mar 02, 2009
    Replaced all 5 possible sensors - moisture sensor bar, flame sensor, hi limit thermostat, thermistor temperature control, and the drying thermostat - to no avail!
    Ended up being the hold coil for the gas valve solenod, 1 of 3 coils used.
    Scholar:
  • 99 Answers
This is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Posted on Feb 07, 2009
WHY DOES MY NEPTUNE MATAG DRYER MDE5500AYW NOT HEAT ...AND WHERE ARE THE THERMAL SWITCH, HI LIMIT THERMOSTAT, AND HEATING ELEMENT?
All those parts are in the bottom front. TURN off the power! then open the front door and remove the 4 screw's, 2 on the hindges and 2 on the other side. Then you can close the door, and pull from the top edges of the front panel(sometimes you need a thin screw driver to free the front) the front panel will tilt forward and then you can lift it off. You will need a Ohm meter to check those parts for continuity. Make sure you remove the wires from the part you are testing.
Sep 30, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Intermittent heating on different cycles?
After a 12-year service life it probably is time to retire your Maytag dryer.
Feb 23, 2014 | Dryers
Dryer heat fails intermittently
Probably an intermittent timer, not the heating element.
Jul 26, 2017 | Maytag Neptune MCE8000AY Electric Dryer
Matag dryer lde412 not heating elec
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
My maytag dryer is not staying hot to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Where is heating element.
the heater is under the drum, remove the screws at the door hinge anda the screws on the other side of the door opening then remove the front panel.
Dec 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Heats intermittently
the herating element might be going bad. disconnect power, remove and inspect the heating element. look to see if its getting thin at any point. as it heats it could be seperatring and only give heat when it cools completely
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune W/D (Stacked) Drying Irregularly
Mj, 90% of the time long dry times are caused by a pinched or clogged vent. Other things that could be causing this are: cycling thermostat trips too soon, if your dryer is a gas model, weak gas valve coils, drive motor centrifugal switch not allowing voltage to the gas valve or heating element. Check the harness to the motor to make sure it is on tight. Catriver...post back.
Sep 25, 2006 | Maytag Neptune MLE2000A Front Load Stacked...
Maytag Neptune MAH5500B Front Load Washer Logo
318 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
