Question about Epson Aculaser C1100 Printer
Power Supply for Epson C110
Hi...
i have a problem with my printer. my printer model is epson C110. its power supply don't working and i dont get any one in our country. so i need to know what is the output voltage rating of this power supply.
i got its input voltage 220-240v ac but what is the output voltage?
pls inform me as early as possible.
thanking u
z_hosen
+8801716556468
Bangladesh
IB4G2008
  • 3587 Answers
SOURCE: i need a resetter for my epson c110 printer....
and what might a resetter look like? I'm unfamiliar with that term, and don't see it anywhere on the Epson user or service manual
got backup?
Posted on Feb 13, 2008
Inky
  • 691 Answers
SOURCE: epson stylus c110..
What do you want to reset and why??
Posted on Feb 20, 2008
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
Posted on Aug 19, 2008
acdr
  • 1913 Answers
SOURCE: i m unable to install the epson tm-u220 printer in windows 2003
http://www.barcodesinc.com/epson/tm-u220-drivers.htm
download driver and install from here
Posted on Jan 24, 2009
  • 55 Answers
SOURCE: Burnt power supply unit of Epson stylus photo R300
try to chec on compassmicro.com they have epson parts their number is also on their website
Posted on Feb 09, 2009
I switch the printer off and now it doesn't want switch back on. Epson L565
Check wall outlet and make sure that power is getting into the innards of printer. If power is there then there is an issue with the power button or the power supply.
Jun 12, 2017 | Epson Office Equipment & Supplies
Bought in US, brought in India, Not getting ON. Epson Workforce 520
If you've plugged it at power socket, here in India, be sure, the main power supply regulator section circuit [SMPS circuit] got damaged. Contact the authorized service center for Epson.
Gopakumar Gopalan Google
Feb 23, 2014 | Epson Workforce 520 All-in-One Color...
Epson 545 power supply replacement
hi,
I did the same stupid mistake of plugging the printer into 240V in India recently and I found the solution. Thought of sharing with everyone. Hope this is not too late. The power supply fix is pretty simple. Please look to the side of the printer where the LAN and USB lines are and see the highlighted screw in the below image. Remove that and then just remove the lid carefully to disconnect the power supply to the internal printer units.
This is the other shot from the printer side wise to reveal the exact location of the screw.
Once you have removed the power supply connection to the internal boards, you can simply slide out the power supply out.
Once you have take out the power supply - take it to the near by electronics shop / repair shop and check out circuit. Mine had two blown up capacitors and one IC Chip which costed me about Rs. 150 (INR) with service charge about Rs. 200.
Sep 16, 2012 | Computers & Internet
It doesn't turn on
First try connecting the printer to a different outlet. If possible, get a replacement power cord and test if the printer will turn on.
If these steps don't help, the power supply or another internal component has failed. If the printer is under warranty, contact Epson. Otherwise, decide if it is worth attempting to locate and fix the problem. (If you take it to an Epson service center, you'll have at least a $50 fee just to diagnose the problem.)
I wish that I had better news for you.
Aug 20, 2012 | Epson Office Equipment & Supplies
My epson 340 has no power
You have to disassemble the printer and check the power supply. Make sure that the fusehas not blown or some other component is damaged. If there are damaged components,to remedy these switching power supply components.
If the power supply is working perfectly, Check all the connections of the logic board andpanel board looking for damaged cables.
Apr 10, 2012 | Epson Office Equipment & Supplies
No power. We had power outages. Is there a fuse inside? thanks... Greg
Check that the Fuse F1 on the Power Supply Board has not blown.
jackpot00_106.jpg Download this service manual for Epson Stylus Photo R1800 ..>
http://www.resetters.ru/download/SM/R_1800_2400_B.pdf Go to page #206 .
Note:Note: Epson manuals are provided in .PDF format, which requires the free Adobe Acrobat Reader. If you wish to save the .PDF file to your computer for later use, right click over the link and choose "Save Link As" or "Save Target As.")
Jul 26, 2011 | Epson Stylus Photo R1800 InkJet Printer
I need a new power supply for my epson rx500 can i do it myself
You have to order the power supply from an Epson dealer, you can't get one here.
Jan 27, 2010 | Epson Stylus RX500 All-In-One InkJet...
Error 4and 3
epson dfx 8500 error coad 4and 3 the power supply was dead .
Apr 29, 2009 | Epson DFX-8500 Matrix Printer
Feb 08, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson Aculaser C1100 Printer Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
