Question about ASUS A6U Notebook
THE LETTERS Q,W,E,R,T,Y & OTHERS DON`T RESPOND.
OTHER KEYS FUNCTION PROPERLY BUT ONLY AS STATED ABOVE. PLEASE ASSIST
  • Derek Fuller
    Derek Fuller May 11, 2010
    Your CAPS LOCK key needs pressing i think???
  • 2,404 Answers
Did anything get spilled onto the keyboard? Sounds like a bad keyboard to me. Get it replaced.
Posted on Feb 04, 2009
My Toshiba satellite C650 laptop has certain keys that don't respond, certain letters, spacebar, shift. I replaced the keyboard, but the same problems persist. The keys that do not function are for example...
ok
solution
you need to open the computer
select c drive
right click it select properties
list will open
select
tools here you will see
drive errors click it will scan for anything not working
if not try this in search bar bottm left
type in drivers
this will open the device manager
look in list
select keyboard
update driver
done
Aug 18, 2013 | Computers & Internet
Hotkeys not working properly
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard. They are located at the top of most keyboards and labeled "F1" through "F12." Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond. Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up. Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key. This key is used to toggle function-key support; when it is toggled on, the function keys will not work. Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software. If the key does not work, press the "F-Lock" key a second time, and test the keys again. If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality. Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.) http://support.microsoft.com/kb/975741 Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database. Agree to the terms and conditions, then download the hotfix. When the download is finished, run the downloaded file and follow the on-screen instructions. You may need to restart your computer after the installation is complete. Your function keys should now work properly.
Feb 09, 2013 | Samsung Series 7 Chronos
Number keys don't work right above letters on keyboard
You have to hold the Fn key, usually blue in the lower left corner of keyboard, for the numbers above the letters to work.
Good Luck,
John Vickers
Sep 18, 2011 | Computers & Internet
I have a hp compaq laptop. i used properly before installing new operating system xp service 2 . but don't use my laptop and my epson projector because automatically don,t display my laptop and...
PC Projector first and Computer next. Usually if the projector powered on after computer you need to use Function keys on laptop normally Function and F4 buttons when pressed simultaneously the computer screen projected through projector. Function keys are identified by green lettering on them.
If you power on projector first and then the computer while they are connected through cable this problem may not arise. Try this and and also Function and F4. This usually fixes the problem. Let us know if you still have problem! good luck!
Sep 10, 2011 | Computers & Internet
My letter keyboard is showing numbers and not letter..please help. (advent laptop)
Laptops do not have as many keys as a normal keyboard so often they include the numbers over letter keys.
So, by mistake you pressed a ctrl or alt or [A] key that simply switches the keys from letters to numbers.
A light or indication must be ON on your laptop indicating that it's Numbers or Letters ON.
Find the key that changes the function and restore the function to letters.
Aug 04, 2011 | Computers & Internet
Certain keys such as the "N" key and some others
Yes, a can of compressed air may solve it. Usually for me I need to remove the trouble keys and soak them in soapy water, dry them, and put them back on the keyboard. Be careful when popping them off as you can break them and have to order a new keyboard.
Please leave good feedback! :) Thank you!
Jul 29, 2011 | Acer Computers & Internet
Where is wifi switch on the compaq laptop?
Well, you haven't given the model number to your compaq. I will try to assist you the best I can, if this doesn't help then I ask that you provide the model number. Some of the Compaqs have a button right between the keyboard and the monitor(it looks like this: http://www.hp-pavilion.ru/Catalogimages/Compaq-Presario-C700/29945.jpg). Others will have a switch somewhere with a orange dot/light near it. If you don't see either of these then there is probably a function key for it. Incase you don't know how function keys work, functions are usually located under the F1-12 keys, you hold down the FN key and press the corosponsding Function. The Wi-Fi function key usually has the same symbol as the one in the picture above. If all else fails and your WiFi still isn't working you could have a more indepth issue.
Nov 20, 2009 | Compaq Computers & Internet
My R61i Function keys are not working
a software issue for sure
The reason why I say this is because you stated that the device could not be detected even with bluetooth driver.
Jan 18, 2009 | Lenovo ThinkPad R61i 14 inch widescreen...
Scrambled keyboard
Is it giving you numbers and symbols? do this: Press and hold the function key fn while pressing the num lock key num lk . This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
Jun 30, 2008 | HP Compaq Presario V6000T Notebook
ASUS A6U Notebook Logo
163 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
