Question about Yahoo Messenger
No incoming and outgoing call
I cannot make a call from pc to pc in yahoo messenger incoming or outgoing.
  • 3 more comments
  • Anonymous Feb 07, 2009
    cant pc to pc call got yahoo mmsngr 9
    i can't make pc to pc call with my yahoo massenger 9.0
  • Anonymous Feb 09, 2009
    i sign in and all goes good then when i click the pc to pc it says messanger is not working what can i do ?
  • shakeel_tuto Apr 28, 2009
    You may hear drop outs or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal.
  • DEKR
    DEKR May 11, 2010
    have you set up for this option in your messenger
Why am i getting this message? .... You may hear dropouts or poor sound quality in this call. Your Internet connection currently has reliability problems, perhaps due to a weak WiFi signal.
Posted on Oct 17, 2009
  • 39 Answers
You may be behind a firewall or NAT. You can set an option that you are; if that still does not work, you may need to open some ports on the firewall.
Yahoo! Messenger uses a variety of ports.
Service Ports Chat & Messenger TCP Port 5050: Client Access only Insider/Room Lists TCP Port 80: Client Access only File Transfer TCP Port 80: Server Access.
Your ISP may block this port, as its used for web hosting.
You can change port in Messenger, Preferences, File Transfer. Voice Chat UDP 5000-5010
TCP 5000-5001: Client Access
If UDP Fails, TCP will be used instead, see below. WebCam TCP Port 5100: Client Access Super Webcam TCP Port 5100: Server Access P2P Instant Messages TCP Port 5101: Server Access
PMs between Buddys may not use the Yahoo! Server, but this is not a requirement.
Posted on Feb 09, 2009
4 Suggested Answers
techprogrami
  • 57 Answers
SOURCE: i'm using yahoo messenger version 9 the call doesnt work
make sure yahoo messenger is in you "allow" list for your firewall
From the Control Panel, click Security Center. >From the Security Center, click Windows Firewall. >in the Exceptions tab, click Add Program.> In the Add a Program dialog box find yahoo messenger and check the box next to it =]
Posted on May 29, 2009
  • 2938 Answers
SOURCE: im not able to see incoming and outgoing text
You may not have Internet Explorer as your default browser but it still plays an important part in the operation of Yahoo Messenger. It sits as a link between your browser and Yahoo Messenger.
For this reasson you must keep it up to date and the support software for IE as well.
Keep your software up to date by using an update checker
http://www.filehippo.com/updatechecker/
Start with IE and then any support software for Yahoo Messenger - Flashplayer - Shockwaveplayer - Java etc.
Cross check by visiting the Yahoo Messenger Scripting Help page
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/notices/mstabuguqscripterror.html
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts
You will have 2 versions if you have 2 browsers so be careful not to delete them.
Start / control panel / programs
delete any old versions
To enable scripting:Internet Explorer8
Click "Tools"
Click "Internet Options."
Click "Security" tab.
Click "Custom Level" button.
Scroll down to "Script ActiveX.controls marked safe for scripting"- enable
Scroll down to "Scripting - Active scripting" - enable
Scroll down to "Scripting of Java applets" - enable
Click OK
Click OK
Restart IE
YAHOO ALL NEW MAIL SCRIPTING
If you are chatting from 'Yahoo All New Mail' and have script problems - try going into 'Yahoo Classic Mail' via the 'Options' tab.If its OK you may have a resolution problem - The screen resolution for All New Mail should be a minimum 1024 x 768 pixels.
Right click on a blank area of your desktop and select 'Personalize'.
Select 'Display Settings.Make a note of your resolution setting. Ramp it up if required.
If this presents a problem go to 'Options' in Yahoo Mail and tranfer to Yahoo Classic Mail.
Posted on Mar 23, 2010
  • 103 Answers
SOURCE: I can't see my incoming or outgoing IM on
The first thing to check is to make sure you have scripting enabled in Internet Explorer. Internet Explorer is integrated into Yahoo Messenger so things that go wrong with IE can affect Yahoo Messenger. Here is the yahoo help page about that: http://help.yahoo.com/l/us/yahoo/messeng...
2) In the Start Menu click on Run. Type, without the quotes, "regsvr32 jscript.dll" and then click OK. Next, repeat the process but this time type in the Run box "regsvr32 vbscript.dll" and click OK. Please note, if you are using Windows Vista temporarily disable the User Account Control (UAC). You can easily turn it back on. On the Control Panel (Category View) choose User Accounts and Family Safety, next choose User Accounts, and then click Turn User Account Control on or off.
3) If the above does not fix your problem and you are using Windows XP, you can update your Windows Script to version 5.7. In my experience helping others, this is the step that has helped the most people. Exit all browser windows and chat programs including Yahoo Messenger before installing. run reginout cleaner to easily fix it
Posted on May 02, 2011
I did not show my message outgoing and incoming message in my screen when i was chatting with my friends
you must download a latest version of yahoo messenger.they have already now YM beta 11.
Jan 09, 2011 | Yahoo Messenger
I am not able to see incoming and outgoing text messages in my yahoo messenger. If anybody knows soltuion please help me
i cannot acesst my account in facebook and i cannot open my yahoo mail in my yahoo meesenger
Feb 24, 2010 | Yahoo Messenger
I want to know what is the outgoing server for yfi. I am using the vodamail account. I can receive emails but can't send from the Yfi connection
Please try this below
Incoming server: pop3.vodamail.co.za
outgoing server: smtp.vodamail.co.za
or
smtp.vodacom.co.za
further lemme know...
Thanks for joinning fixya
Oct 31, 2009 | Yahoo Messenger
I can't call pc to pc
It may have some causes:- First, check your internet connection. You should run the Call Setup Assistant before making voice calls for the first time. To run the Call Setup Assistant: Open the "Messenger" menu in the main Yahoo! Messenger window, and click "Preferences." Then, in the Preferences dialog box, click "Calling and Audio." In the Calling and Audio dialog box, click "Open the Call Setup Assistant." Follow the instructions to test your microphone and speakers and specify your Internet connection. Running the Call Setup Assistant will ensure that you have a high-quality voice experience within Yahoo! Messenger. You can run the Call Setup Assistant at any time to make sure your microphone and speakers are working properly or to change the type of Internet connection you are using. One important thing, your firewall must support outbound TCP (transmission control protocol) connections for the PC-to-PC voice feature to work. You might have a firewall blocking Yahoo! Messenger's PC-to-PC voice feature. If so, you need to open up some outgoing TCP connections. Note that it is the outgoing connections that matter, not incoming connections. In most firewalls, you have to specify a destination port or port range to open. Learn more about which ports Yahoo! Messenger uses. Even if you don't use a firewall, your Internet service provider (ISP) may use a firewall, a network address translator (NAT), or a proxy server that blocks voice traffic. Any of these could prevent you from using the PC-to-PC voice feature in Yahoo! Messenger. Please contact your ISP's network administrator for assistance getting around these issues. You must know that what ports are used by Yahoo! Voice services. Yahoo! Messenger with Voice will work if any one of these TCP ports are open: 5061, 443, 80. At least one of these ports must be open in order to make PC-to-PC or PC-to-phone (Phone Out) calls, or to receive calls (Phone In). If your connection to the web is through an http proxy, then you won't be able to make or receive calls with your PC. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
I'm using yahoo messenger version 9 the call doesnt work
May 29, 2009 | Yahoo Messenger
I need the incoming mail address and outgoing server SMTP name
Incoming: pop3.yahoo.com
Port: 110
Outgoing: smtp.yahoo.com
Port: 25
Mar 19, 2009 | Yahoo Mail
Can not send email from outlook 2003. send: smtp.att.yahoo.com ssl 465
Firstly you need to enable the POP3 settings in yahoo by going to the Options>Mail options>POP & Forwarding.
After that you need  Incoming Mail (POP3, IMAP, or HTTP) : pop.mail.yahoo.com
Outgoing Mail : smtp.mail.yahoo.com
In Advanced Tab Outgoing mail Server (SMTP) : 465 (SSL)
Incoming mail (POP3) : 110 (SSL) OR  995 (SSL)
Jan 02, 2009 | Computers & Internet
Incoming and outgoing identity
# Yahoo! Mail Settings
Unlike Hotmail, Yahoo! Mail offers standard POP3 access for receiving emails incoming through your Yahoo mailbox, by using your favorite email client software. To setup your email client for working with your Yahoo account, you need to select the POP3 protocol and use the following mail server settings:
Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (port 110)
Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (port 25)
Nov 03, 2008 | Yahoo Mail
Yahoo with outlook
The configuration is the follow:
pop3: pop.mail.yahoo.com
smtp: smtp.mail.yahoo.com
User: our username
Password: you password
In the Advanced Tab select "My server requires secure conection" only
Nov 10, 2007 | Yahoo YHT-630 System
Yahoo Messenger Logo
1,177 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
