Question about DeLonghi Pinguino PAC-02 Air Conditioner
Why HP or LP error showing frequently in running period of PAC units?
  • Chris Parrish May 11, 2010
    Ok so is it doing both or just one or the other? those stand for high pressure and low pressure on the refrigerant side. how is it vented? how long is the pipe to outside?
    New Friend:
Condense chock ya gas preees lo ya hai
Posted on Dec 09, 2015
  • 56 Answers
Could possibly be an air filter issue. check your owners manual under trouble shooting for what these codes mean. HP and LP error codes usually mean hig and low pressure.
Posted on Feb 16, 2009
Mr slim ac shuts down and restarts to frequently.
Changing the setting won't affect the way the unit works, only how long it runs for. Rapid switching off and on will kill your compressor in time - check the refrigerant level. Usually short cycling on lp switch.
Oct 19, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
LP HP CF Blue star
11TR Blue star Ductebal AC LP HP CF porbalem
Jun 12, 2012 | Heating & Cooling
.DeLonghi pac A110 PF error code
Probe fault? Temperature sensing probe may have loose connection or water in the tip.
Apr 17, 2012 | DeLonghi DEC 180 E Dehumidifier
LP,HP AND CF APPEARS ON HANDSET AFTER RUNNING THE UNIT IN BLUE STAR DUCTABLE UNIT. PLS SOLVE IT
after starting of ac units it shows lp hp but once reset than the lp hp thing goes away what is the reason for showing lp, hp in the morning when started first time in the morning
Apr 28, 2011 | Heating & Cooling
I have a hayward heatpro model hp2100. the heater will run and heat the pool for a while then shuts down displaying LP on the digital screen, after a period of time it will clear the LP and have running...
LP is an error message refering to the low pressure switch. For more information about it please refer to your owner's manual here. If you decide to persue attempting to repair it yourself and need further assistance, please reply to this post with a new comment or start a new post with your specific question(s).
John
Feb 01, 2011 | Hayward Hp2100 Digital Heat Pro Heater...
I have water coming from the back of the unit when it is on, please help
Air filter,Evaporator coil block or less speed of blower motor or drain pan blocked. Hence first service the unit frequently to avoid not only leak of water but also major problem.
Dec 08, 2010 | DeLonghi PAC C100 Air Conditioner
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
I have a rome Industries Pool heat pump model 105 showing error code LP???? what does that code mean and what do I do?
I happen to work for Rome Industries and can help you out. The "LP" code on your control board represents "Low Pressure". This is referring to the refrigerant pressure within the unit. The unit is equipped with a low pressure safety switch that when activated shuts the unit down. This could be caused by a refrigeration leak, a stuck thermal expansion valve, or even a faulty pressure switch. If you live within the state of Florida contact Rome Industries and you will receive a free of charge service call including parts and labor as long as your unit is under warranty. If your outside of the state please contact your dealer to handle the claim. Have a good day.
May 01, 2009 | Pool & Spa
Comfort Aire PAC-121 problem
E4 shows up on the screen on my PAC-121 when the water reservoir on the right-hand-side is not pushed in all the way. If it is in all the way the switch that it engages may be bad or out of place.
Jan 25, 2009 | Comfort-Aire PAC-121 Air Conditioner
EP to LP problem on VHS tape playback
The problem is dirt, dust or even mould on the VHS tape. You should look on youtube for video's about cleaning a VHS tape. However if it's really bad there is nothing you can do about it. Commercial VHS were only recorded on SP so the quality of the tape means more signal, so less of a problem keeping the video tracked, even if the tape has patches of mould, likely if kept in a basement!
Aug 09, 2017 | JVC HR-XVC33U DVD Player/VCR
DeLonghi Pinguino PAC-02 Air Conditioner Logo
519 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
