Question about Hobart Handler 125 Ez
Trying to weld with Hobart 125 EZ
Good morning-Just purchased a Hobart 125 EZ=I am a novice at welding-read owners manual four times. I am assuming the negative lead provides the heat on the metal to melt the wire flux. How long does it take to heat up the metal-Welding only 3/16" thick metal???? Thanks
If you are using flux wire and not shielding gas, your clamp should be positive and the wire should be negative. Heat is provided by the electrical arc that happens between the wire and the material. Your welder by itself does not pre heat the material and with 3/16 material you should not need to preheat anyway.
The electrical arc is kept consistent by adjusting the wire feed rate and the current applied. You will need to experiment with these settings to find what works best with your welder. For this welder and 3/16 material, I would suggest you start at the upper end of the current scale and about a third of the way up on wire speed. The welder might have a chart for these settings in the manual or inside cover.
If the wire feeds too fast, it will push the probe around and you will feel pressure as the wire feeds out. If the speed is too slow you will get large spatters and intermittent arcs. When properly adjusted the arc will sound even and consistent. The arc gap should always be about 1/8 of an inch.
To maintain enough heat for good penatration, do not move the probe too fast, work in a pattern and watch the weld pool (melted metal) and not the arc. Watching the weld pool will clue you in if you are moving too fast or too slow.
I hope this helps.
-Scott
Posted on Feb 03, 2009
Trying to find out what year and information on a hobort welder i thing model # ml604 serial# 3dw-9287 specs 1684 I think this is the right information Thank you
Can't help you with the year,but here's the owner's manual. The serial number should be a combination of two letter and six numbers, like: KK123456. The one you are posting it's not a serial number.
http://www.hobartwelders.com/om/0900/o947h_hob.pdf
Hope this help you. ; ).
Mar 07, 2011 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Welder pulsates
Hello, by pulsates, do you mean that the wire feed is what is pulsating while welding? If so, I have had this as well. I found that by turning down my feed rate, the pulsing stopped and the feed was smooth. I hope this helps. If not, contact me again.
joe
Jan 08, 2011 | Hobart Handler 125 Ez
My Hobart handler 120 won't heat enough to weld. What are possible problems?
If you are using solid wire, you need to use a shielding gas like Carbon Dioxide or Argon. Otherwise you will not get *********** and the wire will leave random blobs.
If you are using flux cored wire, you do not need the shield gas as the core is producing the gas shield.
This should remedy it.
Dec 04, 2010 | Hobart Handler 125 Ez
Where can i get parts for my hobart welding machine but is a old welder
Your local welding shop supply will be able to give you advice, the guys at Lowes and farm supply shops just sell the welders
Oct 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Breaker blow
You may have a short in the trigger leads that is pulling the weld current back through the leads and through the control cable. The short could be causing the breaker to blow. Can you open up the gun handle (disconnect it from the power source first) and check your trigger leads for cuts or nicks. Also check the outer jacket of the cable for cuts which may be deep enough to allow the current carrying copper to touch the embeded switch leads.
Apr 21, 2010 | Hobart Handler 125 Ez
I pluged it in and it popped?
Check welding supply shops that sell Hobart welders.
Apr 08, 2010 | Hobart Handler 125 Ez
Need to try and find a wire feed motor for Hobart 120 Handler.Mine is smoking.I think its a 1997. Thanks
go to praxair ,air gas s j smith or any welding shop they can get it for you,
Mar 16, 2010 | Hobart Handler 125 Ez
Wire doesn't feed and I cannot get an arc
Fist look and check the contact tip. ensure the tip is the correct size for the wire being used as well as the wire feed rollers. the contact tip is were the wire collects the power,
If it's only 3 day's old send it back, dont star strippin it down or you Garantee will be made invalid.
ken
Jan 09, 2010 | Hobart Handler 125 Ez
Wont spark or weld
lets go over the basics 1 do you have it set up ,the wire feader turned up at least to see if it sparks 2 do you have itset up at least to see if the amps are on enough to get a spark? try thoughs and see where you are,then turn those up enough to weld with . (make sure your wearing a good helmut .please you only get one pair of eyes!!!!!!!!! )hope this helps jojogunn.
Mar 13, 2009 | Hobart Handler 125 Ez
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Hobart Handler 125 Ez Logo
892 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
