Question about KDS Valiant 6380iPTD-01 Notebook
My vailiant ecotec 28 keeps breaking down
Weve had a split nylon hose replaced with copper worked for a few hours then the diverter stated to leak due to preasure, new diverter worked for an hour or so, then preasure builds and breaks down again, could there be a problem the engineers are not picking up weve had no hot water/heating since middle of december, boiler is only 3 years old
Leaking screen wash bottle
You'll need to pull the bottle out to see where the leak is occuring. Look for
* split hoses from the pump(s). This is the more likely cause of the leak.
* pump O-rings. Remove and clean, and reassemble.
If the bottle itself has a crack or split, I've had success using a large 40W soldering iron with a flat tip to to CAREFULLY heat the plastic (often something like nylon) and effectively weld the split back together.
Sep 07, 2011 | 2005 Volvo V50
I have a 1998 Ford Explorer. I have changed the left rear caliper due to malfunction. My problem is that break fluid is leaking. What to do?
i`m guessing that the leak is coming from were the brake hose is fastened to the caliper,did you make sure that the surfaces were clean and free of dirt before re-installing the hose to the new caliper,also there should be a copper washer on each side of the brakes hose were the bolt goes through.check and make sure you have this and that there is not an old copper washer stuck to the caliper if you are using new copper washers supplied with the new caliper.they line will not seal if there is more than one washer installed
Mar 04, 2011 | Ford Explorer Cars & Trucks
It is working for an hour, and switches off. It can not be switched on, but next day it works for an hour.
There is a thermal break down of the semiconductor components. Check which part is getting over heated.
Keep the TV back cover slightly open and try with a cooling fan. Table fan or air circulattor. This problem may be due to the copper track of the PCB.
Aug 22, 2010 | Televison & Video
Electrolux EOB976: cooker hose or copper pipe?
The regulations state that the proximity of the hob to the cooker would dictate the use of a copper pipe to supply the hob.
Hope this helps.
May 26, 2010 | Cooktops
96 chevy G 30 my breaks go out some time, tha powre stering is leaking,it seems when i fill it back up breaks work fine where do i start?
find out were your leak is? either in the pump itself or the hydrobooster area and replace the component that is leaking fluid
Jan 22, 2010 | 1993 Chevrolet G20
Why do I have low pressure on sprayer and still have water coming out of faucet when I am spraying.
Get the replacement parts in about 10 days FREE from PP. Call 800-732-8238. The flow is the diverter tee. I had the cartridge and aerator replaced. And then I replaced the diverter tee. I ordered the parts on a Saturday; got them the following Saturday. Below is a video to remove the diverter tee. The video is helpful, but doesn't tell you about the other 2 connections. The "spout" connection and the connection to the right (the "t" part) is simply a wiggle off. Then after those are off (with lots of water coming out - get towels ready), then you can crawl back from under the sink and get the sprayer off. The sprayer procedure is in the video (push up/in hose) then pull down gray collett. These faucets were discontinued in 2005; a plastic disconnect is now available for newer models. Also, we had to replace the cartridge and the aerator to keep it from leaking out of the handle. The problem we originally had was not having equal pressure with the faucet and the sprayer. The faucet would be running and then the pressure would go down. The sprayer would be weak when the faucet was on - never getting full pressure from the sprayer, just a trickle. It was "moody."
26 Series:
Removing Diverter/Quick Connect:
Dear Customer,
Thank you for contacting Price Pfister, here is a link to a video that will guide you through the steps on how to either remove the quick connect or the diverter.
http://www.pricepfister.com/about/diverter.aspx
You can go to PP's website and see and "Exploded View" of the model you have. If in the model number it states "XX" that is the finish - for example, mine states Marielle Kitchen Faucet "26-3NXX" The "3" is the number of holes (put a 4 in its place for 4 holes). The XX is SS for Stainless steel - even though it's chrome.
Oct 29, 2009 | Price Pfister Marielle Kitchen Faucet with...
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
My frigidare diswasher is leaking from a left side black hose
Check the hose first - it could be split or damaged esprcially if it's old. Check all the clamps to be sure they are tight. Chack all connections to the dishwasher and drain spur under the sink. Check the drain trap fro any leaks.
Mar 27, 2009 | Frigidaire Dishwashers
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
KDS Valiant 6380iPTD-01 Notebook Logo
99 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
