Question about Kitchen Ranges
Broiler shuts off after a few minutes of use
I have a Kenmore 790.78632 gas range that is working great, except for the fact the broiler shuts off after about 10 minutes of use. I bought it new about 14 months ago, any suggestions?
    Problem Solver:
  • 12 Answers
Water pump probabley to slow causing overheat and shutoff some makes have variable speeds
Posted on Feb 03, 2009
Why won't the broiler flame on my kenmore gas stove adjust?
you may have to replace the orifice with a smaller one. Follow the gas tube from the broiler to see if it runs thru the same regulator. Some units use a pressure regulated gas valve.
Aug 22, 2014 | Kitchen Ranges
Kenmore gas range model #790-77471790 oven stopped working...broiler and stove top still work
If the oven has stopped working but the broiler continues to work, it would imply that the bottom heater is broken. When you are using the oven, both the heater for the broiler and the bottom heater are at use. The broiler only uses the top heater.
Elisa Jed '
Aug 19, 2014 | Kitchen Ranges
Broiler flame becomes weak
check lower broiler for clogs - spider webs etc
Jul 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Kenmore Oven Problem I have a Kenmore 79012 Range. The burners and broiler work fine. The ignitor comes on in the oven, but it will not light. After a few minutes I can smell gas, but the ignitor is still...
the ignitor has to be on before the gas valve opens up and until the stove recognizes a flame, if it doesnt the gas will shut off and the ignitor will cool off, If you use the self clean setting to clean the oven you will destroy the ignitor much faster because they are only rated for about 1000 degreese for just a minute and self clean keeps it around 800 for an hour or so. You may just need to replace the ignitor.
Jul 28, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Gas leaks into oven when i turn on the broiler
You have what we called delay ignition. may be the broiler ignitor too far away from broiler, partially clogged broiler orifice or bad ignitor, I"ll check the Amperage on the ignitor, it should draw above 3 AMPs, if not, then I'll change the ignitor first then check the orifice. Have fun.
Dec 04, 2008 | Dynasty DGRSC 36-4CB Gas Kitchen Range
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
88 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
