Question about HP OfficeJet 6110 All-In-One InkJet Printer
My HP 6110 has literally died on me. Cannot turn it on.
A few days ago the scanner function stopped working. Now, the whole thing is dead. I have tried taking out the plug and trying to start it -- nothing. The machine is correctly plugged in. It is protected by a Belkin, but we have no outages or power surges. It is not that old, and is not used excessively. Up to now it has been the best printer I have owned.
  • Thomas F. Schneider May 11, 2010
    Try connecting directly to the computer first. See if it is still listed in the computer software.
Just to tell you:
1. I checked that the HP was still on the computer. Result: affirmative
2. I unplugged everything relating to the HP and reset. It came back to life!! Copies and prints fantastically again
3. Still cannot get a response from the Scan function. Tried everything, inc HP troubleshooting. If you have any ideas on this you will be great heroes!!!
Thanks for help so far -- at least we have a 50% functionality
cmohalloran@avired.com
Posted on Feb 04, 2009
Hp 6110 scanner making noise i can do any thing else because of that scanner light doesn't move, move little on scanner glass then come back on right hand side and keep making noise some time i can see...
If you cleaned the scanner glass before the problem began, it sounds like you messed up the homing strip underneath the glass. The scanner is trying and trying to find its home position and it can't. There is no way to disable the scanner to use the other functions. This is the downside to All-in-One machines. If one function (most commonly the scanner) stops working the entire machine won't work. I own a Cartridge World ink refilling store and I always caution people against buying all-in-one machines for this reason. It sounds like you'll need to buy a new printer, unless your printer is magically still under warranty you could call HP and ask what they can do for you. They'll probably just recommend you buy a new machine anyway.
Feb 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a officejet 6110 and when I turned it on the other day the scanner moves all the way to the right but never stops and sounds like a gear keeps slipping. Then a scanner failure appears on the screen...
Mr.Coiroj
This kind of problem creating from main dust only in Scanner Assambely so it must remove and make it clean; while you making clean use Soft Cloth to all the Glass to Clean; Do Not Apply Any thing in the Glass try it....
Jun 27, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 scanner glass is cloudy
Here is how, but it seems a lot of work.
- Remove all the torx-screws
- Remove the little glass on the left side
- Remove the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
- Remove the Control Panel itself (another two latches&move to the left)
- The whole top of the 6110 is attached to the bottom with 4 latches. I remove that, turn it around and clean the glass.
Note: The cables between 6110-bottom and control panel/feeding unit are long enough to set those things aside.
Dec 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer will not turn on
I need only driver CD for HP PSC 1410 All in one Printer, scanner ,copier.
Please send this driver through my email mybesthagos@yahoo.com . Due to this I stop my job.
Dec 01, 2008 | HP PSC 1410v All-in-One Printer
Scanner failure, while booting up, blocks all other functions.
no you can not disable your scanner
you ust have to repair your scanner
if you have any warranty then go for it
or visit any technical person who can check cables and scanning tube of your scanner
Nov 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one
maybe you could try to reinstall the driver?
Oct 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Error message
Unfortunately, if an HP scanner quits functioning, the whole unit is dead. You may want to unplug the printer from its power source and USB cable for about 5 minutes, plug them all back in and then retry. Sometimes, a scanner job can get stuck in the spooler and cause the whole thing to stop working until the job is done (even though there isn't a job to do). I had this issue once and this worked.
Jan 20, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Mac OS 10.5 Leopard
I was able to get my 6110 to scan by downloading HP_Installer_PSC7100_v9.7beta.dmg .  I saw this on XLR8YourMac for another HP multi-function and on a lark I decided to try it.  During the installer it won't detect the 6110, but you are able to "Skip" to the next step until it's installed.  Then, launch "HP All-in-One Device Chooser" and you will see the 6110 listed.  After I choose it there, I was able to use "HP Scan Pro" with the 6110.  I've not really tested the rest of the applications.
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
All in one printer
This seems to be a paper registration problem for the copy function only that is an HP thing Good old HP so innovative and so secretive none of us know whats going on most of the time. Two things to try. Take the stack of paper out of the feed tray and riffle so that it is slightly 'untidy' switch off the device , load the paper, switch on- see what happens. Next look at the software disk- there is usually a fully comprehensive reference manual on there [more than in the book]- check that out then come back.
Sep 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110
Is the ticking sound coming from the right side near the bottom? Or the left side near the top. If it is the right bottom then you're looking at a service station. If it is the left top then a scanner unit. Scanner unit is not available from Hp. You can try dismantling and cleaning all mirrors and lenses (usually doesn't work). If it is the service station, you are probably going need parts that are not availble.
May 01, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
