Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error code 6a00 on my cannon mp600 what does it mean
Dear Tech
Hi I have a cannon mp600. prints great until this morning. When i turned it on there was the error 6A00 code on the lcd screen.
What does it mean and can i fix it myself?
Kind regards
Phil Pwell
  • 3 more comments
  • Anonymous Feb 03, 2009
    This morning I did some printing,then the printer stop.On the LCD read check printer 6A00
  • Love2Ski Mar 28, 2009
    same
  • Anonymous Apr 05, 2009
    same as other user
  • sharon_2664 Apr 05, 2009
    my mp600 was working fine and all of a sudden error code 6A00 appeared on screen and now it wont work
  • Anonymous Apr 10, 2009
    I tried to print something but I got the message error 6A00
Simply move the cartridge back and forth a few times
Posted on Mar 02, 2009
Error code 6A00
I HAVE A CANON MP600 ALL IN ONE PRINTER. SCANNER etc., AND I HAVE AN ERROR CODE OF 6A00 COME UP! both green and amber lights flashing and will not allow me to print... can you please help
Aug 23, 2010 | Canon PIXMA MP600 all-In-One InkJet...
How do I fix error 6A00 on my canon MP600 printer?
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6A00 green and yellow lights are flashing. Printer will not print.
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Apr 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
When trying to print, paper gets jammed, screen comes up with 'error code 6A00'
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Feb 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon Pixma MP600 printer has an error coming up of 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jan 29, 2010 | Canon Pixma MP600 Printer
Cannon Mp600. I have an error code 6A00
Try
Solution 1:
Solution 2:
Solution 3:
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer error code 6A00
Heello there
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The printer cites error 6A00. I'm told that this
With thanks to a canon tech :-)
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
May 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp600 error 6A00: After you check for loose paper
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,052 people viewed this question
old marine
old marine
