Question about Combi Centre DX - Mango
Worscester 24i boiler
No heating or hot water gas wont ignite lost water pressure now refilled but seems to be airlocked anyone know how to vent boiler
  • blue236 Feb 19, 2009
    it should have an auto air vent that does itself i think other way to do it is see if rads have air. hope this is of help
  • Rod Davies May 11, 2010
    The manual vent [automatic pressure relief valve] is inside the casing usually a large red knob which can be turned by hand situate at the lower right - You should have a pipe which goes through the outside wall from it This vents and will empty the whole system inc rads
    The auto vent is usually close to the water pump and has a small red/black knob [short biro top size] this should be open by 1 turn from closed This vents the air from the boiler only, automatically when in use
    Lost pressure = leak maybe through manual vent - have a look outside where the vent pipe goes through the wall
    If your pressure is about 1 bar then its something else Does the fan [on top of boiler and at start of the 110mm vent pipe] work. This should come on when there is any demand from boiler even if it does not fire up
  • 3,181 Answers
There is sometimes a large screw on the front of the of the pump un screw a bit and see is air comes out
Posted on Apr 06, 2010
Ran out of oil, when refilled managed to get heating working but oven not
How to bleed and restart your oil heating. - Instructables
InstructablesGo to the oil tank and make sure there's oil in it, or you'll be wasting your time. ... you to get lucky but it has happened to me and it seems to help get the fuel moving a ... I am thinking the boiler is not working so do not want to spend money buying lots of ... Bleeding brilliant - now the wife doesn't have to know we ran out of oil!Missing: oven
how to mend it .com - Clearing airlock from riello oil burner? > Heating, Oil Filled Radiators
The temp knob on my bosch oven has stopped working. ? Search: Go ... I've now replensihed the oil but the system keeps cutting out after a few moments trying to ignite the oil. ... With guests arriving to rent my house yesterday, I ran out if fuel,refilled and ... Have now managed to restore heating and hot water to my house.
My Craftsman lawn mower wont start after it ran out of gas ... > Manage My Life > Questions
Dec 21, 2015 | Ovens
Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get
Hi Steve, I am not a plumber but have done a lot of DIY on my own heating system with Worcester Bosch combi boiler! I believe that you can have the hot water on without the heating system filled, just turn all the settings as for summer use and the thermostat right down so the heating is forced to stay off!
Nov 07, 2014 | Water Heaters
Hello, I have a Worcester 24i boiler and the heating is working fine but the hot water will only stay hot for about a minute at a time in the kitchen sink, the shower is ok but only when the heating is on....
The link is to how to flush a tankless system.
This should be done once a year.
This link is to the manual on the unit.
On my unit, it the hot water is running slow the unit turns off and the hot water goes cold, so for me its run the water on full.
Dec 21, 2017 | Water Heaters
My worcester bosch 24i junior pressure keeps dropping if i have heating off for an hour i have to top up boiler and reset also when i have heating on the pressure jumps right up to over 4.0bar
When water is heated it expands. To deal with this all boilers are fitted with a small expansion vessel which is like a reservoir which holds the excess water.
This expansion vessel is like a balloon in a metal pot. When the water goes in the metal pot the baloon squashes a bit to make room for the extra volume of water. When it cools the balloon pushes the water back into the heating system.
What has happened is your expansion vessel no longer works. When the water heats up there is nowhere for it to go so the pressure jumps up to 4 bar. The Worcester boiler lets high pressure water escape (most boiler allow this to go through the safety valve at say 3.5 bar).
When the water cools the pressure drops very low as the volume of water contracts.
The problem is your expansion vessel - normally a little red painted metal cylinder inside the boiler.
Dec 22, 2010 | Bosch Water Heaters
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
Worcester 24i combi when in shower hot water flicks on and off can hear gas igniting and extinguishing
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Aug 06, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
The hot water and central heating wont work together
what size of gas line is going into boiler and water heater? is it black iron ? natural gas or propane? have you checked gas pressure at water heater and furnace ? if they work fine individually then you have a problem with incoming gas pressure. Call gas company and ask them if they would come out and check gas pressure.
Feb 03, 2009 | Water Heaters
Combi Centre DX - Mango Logo
171 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
