Question about Dell Inspiron 1525 Notebook
Reseat the hard drive
THE computer wont boot in try testing says to reseat hard drive how do i do this
    Scholar:
  • 96 Answers
Hi, You can try this out to reseat the Hard Drive
First safety Steps:
  1. Ensure that the work surface is flat and clean to prevent the computer cover from being scratched.
  2. Click Start reseat the hard drive - before7.jpg , click the arrow before8.jpg icon, and then click Shut Down to turn off your computer.
  3. Disconnect your computer and all attached devices from their electrical outlets
  4. Disconnect any telephone or network cables from the computer.
  5. Remove any installed cards from the ExpressCard slot and the 8-in-1 memory card reader
  6. Turn the computer over.
  7. Slide the battery release latch until they click into place.
  8. Slide the battery out of the battery bay.
  9. Turn the computer top-side up, open the display, and press the power button to ground the system board.
    battery
1. Turn the computer over and remove the two hard drive screws.reseat the hard drive - spears_h.jpgg src="http://i.fixya.net/uploads/images/spears_h.jpg" alt="spears_h.jpg" class="h_mi" />
screws (2)
hard drive
2. Slide the hard drive out of the computer.
3. Slide the hard drive into the hard drive bay until the drive is fully seated.
4. Replace the two screws to secure the hard drive Then again you can try
Posted on Feb 03, 2009
Don't have a hard drive what do I need to do to get it working
Posted on Jun 25, 2009
Screen won't come on
Computer does not boot up The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Apr 05, 2013 | HEWLETT-PACKARD 320GB 2.5" SATA HDD Hard...
Hard drive doesn,t power up. does this mean that it's bad?
Mar 31, 2013 | eMachines T6216 160GB Hard Drive...
Blk screen, won't start, tried reboot but nothing. Screen stays blk no hard drive noise only CPU fan running.
Mar 05, 2013 | Computers & Internet
Reseated hard drive, computer wont re-boot, asking for disc?
Check The BIOS to see if the hard disk is detected. If not then -
Check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 10, 2012 | Computers & Internet
Lightbulb is red and flashing next to turn on switch. What is the cause?
Could be a number of things. Usually a hardware problem Try:
-removing and reseating the RAM chips, test, if no good, try
-remove one RAM chip, test, if no good, try
-unplugging all components (hard drives, CD/DVD drives, floppy...anything that consumes power), test, if no good, try
-letting the system sit for 10 minutes, powered off too cool down, test, if no good, try
-a different CPU, test, if no good, try
-a different motherboard
If any of the above steps gives you a different result than the flashing red light, then the offending part has been removed from the test equation.
-Reseating the RAM can fix thermal creep
-If you have one bad RAM chip out of multiple chips, removing and replacing them one at a time can show which chip may be bad.
-If a drive/component is bad, removing that component can allow the computer to boot
-Heat can cause component failure or erratic behavior (no boot, etc)
-A failed CPU can prevent boot or POST
-A failed motherboard can prevent boot or POST.
Best of luck!
--JK
Mar 03, 2011 | HP Compaq d530 SFF PC Desktop
My Toshiba Satellite A215 starts to boot but the hard drive never spins up. The screen remains black and it never goes into POST. I took the battery out and tried to run without; reseated the hard drive,...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 21, 2011 | Toshiba Computers & Internet
Problem with hp compaq nc8430 no see my hard drive Went I reinstall windown xp my hard drive it not present
Go into the BIOS setup (press f10 during boot process), then SYSTEM CONFIGURATION and disable SATA NATIVE SUPPORT. Try installing XP again and it should see your hard drive.
(If it will work then please vote for me).
Thanks
May 17, 2010 | HP Compaq nc8430 Notebook
17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • Feb 04, 2010 | X2Gen MG19MY 19" LCD Monitor
    Inspiron 1525 was working fine yesterday but today wont boot. Says it can't access the hard drive.
    Does the hard drive LED flash and the hard drive spin up when you bootup?
    If it doesn't then you could have a faulty hard drive or a fault disk controller.
    Reseat the hard drive to see if it is a connection problem.
    If the problem still persists then to test if the hard drive is faulty, remove the hard drive and connect it to an USB hard drive adapter.
    Connect this to a working computer's USB port and if this computer sees it as an external hard drive and you can open the folders and files then the hard drive is OK.
    If not then the hard drive is faulty and you need a new hard drive in the Dell and Windows installed etc. to get the Dell operational again.
    Jul 14, 2009 | Dell Inspiron 1525 Notebook
    Dell Inspiron 1525 Notebook Logo
    7,238 people viewed this question
    Alun Cox
