Question about Crosley CDE6000 Electric Dryer
Crosley dryer smells like smoke when in use
Crosley dryer problem
  • 640 Answers
Ok we need a good cleaning,,,the lint is backing up,,check your exhaust system..onthejob
Posted on Feb 03, 2009
My hotpoint tumble dryer almost caught on fire the house was full of smoke can l claim
Only if you can prove that the fire/smoke was caused by a machine defect and not a lack of cleaning the unit out once in awhile.
Jun 20, 2016 | Hotpoint Dryers
How can i test my dryer to find out if the motor is bad
If the drum goes around, your motor is working.
If the drum doesn't go around, the belt could be off or broken, or the motor could be bad.
Try to listen for the motor starting up as you turn the dryer on. If it sounds like it is running (an initial 'bump' followed by a quiet hum), chances are it is a belt problem.
If you can't hear the motor running, or it is a loud buzz, or there is the smell of burning insulation or smoke, chances are your motor is bad.
It is also possible that the selector switch that controls everything is not turning the motor on (bad selector) or the overheat safety switch is malfunctioning, but these need to be tested by taking the dryer apart.
Nov 18, 2014 | Crosley CDE6000 Electric Dryer
Can a dryer heating element smoke if dryer is not running?
Something fried and is shorted. Unplug this unit right away. There are a few sensors on this that could have overheated as they failed causing this smoke and smell, but UNPLUG UNIT!!! Then look at what has fried.
Aug 31, 2012 | Whirlpool Dryers
IM REPLACING HEATING ELEMENT FOR MY CROSLEY DRYER....I DIDNT PAY MUCH ATTENTION TO THE EXACT WIRING....4 RED CONNECTORS...2 HOOK UP TO THEROSTAT..AND 2 TO HEATING ELEMENT....I CONNECTED THEM AND CLOSED...
unplug dryer....if you take the top back panel off, there should be six screws and look in the top left hand corner there should be a schematic for the dryer. All appliances have then located in this area, unless someone has took them out. Hope this helped Tim
Feb 22, 2011 | Crosley CDE6000 Electric Dryer
Dryer smells like its burning
Check the connections to make sure that they are tight enough... sounds like a loose connection...
Check the last couple of paragraphs of this tip...it is the same with a dryer...
http://www.fixya.com/support/r4502309-oven_repair_oven_will_not_work_all
heatman101
Apr 07, 2010 | Crosley CDE6000 Electric Dryer
Smells like burnt diesel or very hot smell
Can't help thinking that either you don't have the revised operating instructions, or the "Sensor Dry System" is not working properly. Download the revised instructions here [http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6231 ] and see if this helps. Otherwise have the sensors in the machine tested.
Mar 12, 2010 | Crosley CDG6000 Gas Dryer
Crosley dryer..it squeeked we oiled the pullys
Did it smell like burnt rubber or maybe plastic burning? After you try to run it for about 10 seconds (and it won't run) then you touch the motor (with the dryer unplugged) it is hot?
It sounds like the brushes could be dirty due to the lag you placed on the dryer when it was installed incorrectly possibly.
OR
While it is plugged in, are the lights coming on in the dryer when you open it?
It could be a fuse if it has no electric going to it (the light does not turn on)
OR
Will the drum spin if you attempt to turn it manually?
THe pulley or another item on the belt system could have burned (ruined) when it was installed incorrectly.
Try to walk through each piece of the system that was affected by teh incorrect installation and see if there may be an item that is not working correctly; this could be an easy fix.
Hope this helps
Sep 06, 2009 | Crosley CDE6000 Electric Dryer
My dryer smells like smoke
just ry to run in on air dry for a while mayee wth dryersheets. charcoal and baking soda are also good at absorbing smell if you can find a way to implement them maybee baking sod box in dryer not running
Jul 09, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Dryer smoking, burned rubber smell
if the rug has a rubber side it will melt make sure dryer is clean and no left over burnt material ..
Sep 18, 2017 | Dryers
Smells like it's burning and smoke coming out of chimney vent
Get the filter housing out of the machine and wash it out. Blow out the blowers housing. Change the control thermostat.It mounts right next to the fuse on the back:
Dec 07, 2008 | Roper REX4634KQ Electric Dryer
Crosley CDE6000 Electric Dryer Logo
135 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
