Question about Sony Cyber-shot DSC-W80 Digital Camera
'Format Error' I've got a S780 and when I put my memory stick duo in an error message reading 'Format Error' appears, any ideas?
  • 10,594 Answers
Seems memory stick has some file error and camera firmware sense it.
Please format memory stick by going in to camera Menu, Format, OK.
Posted on Feb 03, 2009
  • Rafibaby2000 Aug 28, 2011
    My memory stick is saying "file error" and I tried going in to the camera menu, clicking format, and ok, however, the option is to erase everything on the memory stick. I would like to recover the pictures that show file error. Are there any options in order to correct the error and get the pictures back?
When you turn on the camera, message Memory stick error appears. Camera works fine with internal memory but not when using sony memory stick PRO DUO
Try to format memory stick through camera menu to solve this problem and if camera wont allow to format then try/ replace memory stick as this PRO DUO could be defective.
If another memory stick gives same problem then memory stick slot connectors could be bad and visual check by local camera repair shop is required.
Thanks.
Feb 27, 2011 | Sony Cameras
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Internal memory formatting error to sony DSC-T2 camera error c:13:01
In DSCT2 Camera, the C:13:01 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Internal Memory or with the Memory Stick.
The Symptoms are:
1. Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
2. Unformatted "Memory Stick Duo" which can be resolved by formatting the MS in the Camera.
3. "Memory Stick Duo" is broken or not compatible which can be resolved by inserting a new compatible MS.
4. There may be an issue with the Hardware part also, which can be resolved by the technicians.
Try turning the power off and on again, or taking out and inserting the "Memory Stick Duo" several times may also help in resolving the issue.
Thanks.
Oct 21, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
When i turn on my camera it appears "error formating memory stick"
I inserted adapter and memory stick in my sony cyber shoot camera and keep getting format error. How do I format the memory stick
Jun 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Sony memory stick pro duo format error
Use this memory stick in other Sony camera to confirm it. Problem still exist means memory stick is bad/ internal breakage.
Jun 12, 2008 | Sony Cyber-Shot DSC-S75 Digital Camera
Sony Mavica MVC-FD2000 can't read memory stick...
THE CARD PROBLBLY HAS NOT BEEN FORMATTED...ARE YOU SURE IT IS A MEMORY STICK PRO "DUO" THERE ARE DIFFERNT KINDS OF MEMORY STICKS (PRO DUO, PRO, QUAL, ETC.)
Feb 21, 2008 | Sony Mavica MVC-FD100 Digital Camera
Memory Stick Duo Formatting Error
when i turn on slide show the slide show music is not working and it is error of coming to show the music download music from pc and connect to pc
Jan 06, 2008 | Sony Cyber-shot DSC-T9 Digital Camera
Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Nov 05, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
197 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
