Question about Hauppauge WinTV PVR2 (99016) Video Capture
Failure to laod programme
I have been using WinTv to copy analogue video tapes to my hard disc. Now I get a message when I try to start the programme "WinTv initialisation error hTV=0" I don't seem able to get around it at all. Help!
    Problem Solver:
  • 17 Answers
Try sage tv or beyond tv software
Posted on Feb 03, 2009
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
How to copy 8mm tape using DCR-TRV350 to pc.
You will need an analogue to digital converter box. You connect the camera to the converter box with analogue cables and connect the A/D box to the PC with a firewire cable.
Note: Many mini DV cameras with analogue inputs can act as an A/D Converter box.
Jun 05, 2011 | Sony Handycam DCR-TRV350 Digital Camcorder
When I try to record a show. There is no picture on the disc when I'm done. Its just a white noise screen. I finalize the disc too. there is no prompt to tell me to format the disc.
If the disc playes back then the problem is not with the DVD unit. In order to record white noise, the channel selected for record is probably not tuned in. Try recording the same channel on to video tape and see what results you get.
Mar 09, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Convert analouge video into digital format
The analogue video format can be converted only with a conversion software/ harware installed into your PC. This might be expensive and is used by studios for conversion. The analogue video is processed and compressed before it is converted and written to a disc. On the other hand you can use the new camcorders to input the analogue to be written into the drive/hard disc/ which can be transferred to a PC in digital format. Hope you try this out. Good day
Aug 16, 2010 | Sony Handycam CCD-TRV78E Camcorder
Sony dvd rdrhxd870 Set to record 2 programmes the first programme is recorded and then the guide plus channels all shut down and I have to reset again. Tried 24hour shutdown as Sony shop suggested no luck
Contacted Sony shop Cheshire Oaks and they said that It is not a fault in the dvd. The north west is going thro having to reset tv's as the Analogue Signal is being shut down. The Transmitters are interferring with the Hard Disc on my dvd and lots of other people are also having this problem. Although the date for the shutdown was 3rd Dec. not all the analogue programs have been turned off. I will have to wait until
the week before Christmas and things should be back to normal.
Dec 07, 2009 | Sony Televison & Video
No signal
Try video input using a dvd - if you are using a digital cable box (or satellite) use the a/v outputs (yel red wht wires)to hook to video in of TV. If you are using standard cable hook the cable through a vcr if available and hook the a/v of the vcr to video in of the tv.
Otherwise is tv(to be used) on Ch3?
The TV tuner may be defective.
If this helped Vote/rate me.
Oct 05, 2009 | Televison & Video
Can NOT copy aN original DVD made from Sony Camcorder DCR-TRV27
Try Finalizing the DVD disc on the Camcorder or the DVD Recorder before trying to copy the DVD on the Computer.
Jun 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Convert a Hi8 to cd
Hi 8 tapes are analogue and need to be converted to digital before a DVD can be made of them. You can pass the signal through a digital video camera to the computer to convert them. Only very short videos could be copied onto a CD as most video files are much larger than a CD's capacity.
I'm not sure about digital 8 but maybe the camera only has an analogue output? If the lead goes to RCA plugs - that is analogue. A firewire socket means a digital output.
Sep 01, 2008 | Sony Handycam DCR-TRV520 Digital Camcorder
Recording
Connect the analogue inouts of the recorder to the monitor or tape outputs on the mixer.
Nov 27, 2007 | Denon DN-C550R 2-Disc CD Recorder
Hauppauge WinTV PVR2 (99016) Video Capture Logo
140 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
Julie Endres
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
