Question about SanDisk Sansa Clip MP3 Player
It wont turn on
When i charge it it turns on but then when i take the usb cord out it just shuts off. what should i do.
  • Bunniew Feb 13, 2009
    I have the Sansa Clip 2GB Red. I cannot get it to go past the first initialization. It turns on but only registers the Sansa Logo.
  • 8,596 Answers
Make sure the hold/lock switch is not engaged first.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
My nyko ps3 controller shut off while it was charging, when it was charging its was blinking super fast. It won't turn back on
try charging it with usb on ps3 if continues try different cord still continues try another usb charging plug, let me know
Nov 09, 2014 | Video Game Consoles & Games
Blackberry curve 8520 wont turn on, no red light wont charge or do nothing when the usb is inserted
maybe a bad cord. if it charges normal on the charger then it needs to be setup so it will charge thru the usb
Jul 14, 2011 | RIM BlackBerry Curve 8520 Smartphone
Psp carge light wont come on and psp wont turn on
You either have a bad battery, or a bad power supply that charges the unit (power cord). If you have a friend that also has a PSP, try swapping out the battery to see if that works, and or try another power cord to see if the charging indicator light comes on. I think that possibly your battery is dead and the power cord might be bad. You can find good deals for both the battery and cord on ebay. Good luck!
Nov 07, 2009 | Sony PlayStation Portable (PSP) Console
I have a GE a735. It wont stay on
Go to the GE website, consult your manual if you still have it, go to RadioShack and see if they might have a replacement charging cord. Maybe at the GE website you can order the charging cord. Good luck.
Aug 04, 2009 | General Electric A735 Digital Camera
PS3 Controller will only work when plugged into the USB
i had same problem turn off your system with controller plugged in to usb unplug controller remove the power cable for a couple of mins reconnect and use controller PS button to turn system on and it should be back to normal. it worked for me
May 31, 2009 | Sony Playstation 3 (PS3) Console
Wont charge
it might be the battery. cause batteries on cell phones only last for so long [depending on how long you've had it] or you might just have a bad phone. go to the phone company where your phone is from, and tell them about it, and they'll probably give you a new phone.
May 23, 2009 | Dual Electronics CECT P168 Cellular Phone
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
Zune won't turn on or charge
probly a lemon battery. Get ms to replace it.
Jan 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
My white ipod wont turn on or charge
maybe when u insert the usb in the pc u just get it with out ejecting the usb because if not it has virus maybe ur pc is not protected i encouter that problem it did not on and play...
Jun 13, 2008 | Apple iPod nano
Wont turn on
hi try charging it completly good luck
Apr 06, 2006 | Thomson Lyra PDP2840U MP3 Player
SanDisk Sansa Clip MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
