Question about Compaq Presario 700 470024-192 Notebook
SYSTEM POWER SUPPLY OFF
CHARGER OUT PUT CHECKED . FOND OK
CHANGED THE BATTERY AND CHECKED : NO USE
  • 1 more comment
  • blumoni2877 Feb 08, 2009
    Replaced power supply 2 times, when I plug it in it starts to turn on then just shuts off wont stay on or charge..
  • DEKR
    DEKR May 11, 2010
    does it stay on when plugged to ac power
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Make and model, and can I get more detail into what is going on?
    President:
  • 2,992 Answers
If the AC adapter is working but the computer doesn't recognize the power (the indicator on the computer isn't on) and the battery isn't charging, the trouble is probably bad solder connections at the power jack. Because of flexing of the power connector, the jack can break loose from the main board and needs to be resoldered. It's not a difficult repair, but involves taking the main board out to gain access to the bottom (solder side). In some cases the main board can be burned by arcing and heating from the bad connections, and sometimes the damage is too severe to repair. The only solution then is to replace the board.
Posted on Feb 22, 2009
7155 Parallax Power supply 12 volt side problems, all fuses and wiring in good working order.
http://d163axztg8am2h.cloudfront.net/static/doc/b5/84/8f1a1586e9cb74379e85d9136830.pdf
Dec 12, 2017 | Parallax Power Supply PARALLAX POWER 7155...
F150 Ford 2011 no crank after earlier in day started ok and parked at home.
Sounds like a dead cell in the battery. Fully charge it with an external charger with it disconnected from vehicle. Take it to a parts store to have it checked with the load system.
Dec 10, 2016 | 2011 Ford F-150
Kipor kde 6700ta GENERATOR
There is, on most generators, a fuse of approximately 8Amps in series with the charge system for the battery.
If the generator produces AC and there is no charge to the internal battery, I would suspect the altenator winding, diode pack or regulator.
Nov 14, 2013 | Computers & Internet
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
Ryobi charger bcl1418
Usually this is indicative of a bad battery. First try a good battery in the tool to make sure it is OK. If the tool is OK, you need to try charging the good battery in the charger to see if the charger is working properly. If the charger is OK, replace the bad battery. Some batteries will show fully charged on the charger but will not supply the power to the tool.
Oct 08, 2012 | Ryobi Drills
Camera works fine with power supply cord connected. It will also charge the battery if connected to camera and power supply connected to ac outlet. Checked battery and it has 8.32 Volts stored in it after...
Your charger is probibly the problem i had a friend of mine that had the same problem but different camera i told him to get a new charger he did and it worked so yoyu do the same goodluck:) please rate this solution...
Jun 06, 2010 | Cameras
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Power supply plugged in but will not charger
u need to check the cable wire, if it's ok then, u definitely need to change ur battery cuz' there's a life-time for a battery.
Feb 02, 2010 | Dell POWER SUPPLY Power Supply
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
Compaq Presario 700 470024-192 Notebook Logo
109 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
