Question about Sony Playstation 3 (PS3) Console
Performed system restore pad wont turn on
I performed system restore, it then said tour hard discs had been corrupted, press ps3 button and ok to restore but the pad wont turn on it just keeps flashing, help
  • paulwillywil May 11, 2010
    have you pugged your controler into the ps3 using the usb lead?
    President:
  • 2,653 Answers
Sounds like you are having a hard drive failure.
Check out my common PS3 problem and repair guide.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 24, 2009
Tip
How to access Safe Mode on Playstation 3.
Execute safe mode when the PS3™ is experiencing the following symptoms:
  • When the PS3™ system is started up, the XMB™ menu is not displayed (only the wave screen background appears)
  • When the PS3™ system is started up, nothing appears on the screen
  • When the PS3™ system is started up, a message stating [The hard disk's file system is corrupted and will be restored.] is displayed > [OK] > Restore operation > Restart
    Original message is displayed again or the system stops during restoration.
  • When the PS3™ system is started up, a message stating [The hard disk's database will be rebuilt.] is displayed > [OK] > Rebuild > Failure > System stops while formatting hard disk drive.
  • The system stops while restarting after a PS3™ system update or while updating or rebuilding the database. The situation does not improve even when the system is restarted.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
    safemode1.jpg //
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
    safemode2.jpg //
Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System
In Safe Mode, you will have the following options:
  1. Restart System - Ends safe mode and starts up the PLAYSTATION 3 normally.
  2. Restore Default Settings - Performs the same operations as [Restore Default Settings] on the XMB™, and also deletes PlayStation®Network account information from the system.
  3. Restore File System - Attempts to repair all areas on the hard disk drive where files can be saved. Corrupted data may be erased if it cannot be recovered.
  4. Rebuild Database - Deletes messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information.
    This operation may take a long time depending on the type and number of data items.
  5. Restore PS3 System - IMPORTANT: All data will be lost by performing this step.
    This will reformat the hard drive on the PLAYSTATION 3, deleting all data and restoring it to as if it just came out of the box. This is the same as [Restore PS3 system] on the XMB.
  6. System Update - Updates the PS3 system software. This can only be done with an update file already saved on an external storage media.
on Oct 11, 2009 | Sony Playstation 3 (PS3) Console
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    What do i do when it says hard disc system is corrupted on my ps3
    Ok try to follow these steps in order to restore your hard disks structure again.
    Step 1. Turn the PS3 off into standby mode (red light on)
    Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off, release the power button.
    Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
    Step 4. The PS3 will start up asking you to connect a PS3 connector via USB and press the PS button. Do this and then go onto the next step.
    Step 5. A menu will then load. Choose option 3 "Restore File System". The PS3 will restart and may report that your hard drive is corrupt, ignore this and click on "OK" to continue. Let the PS3 do its thing and hopefully when it restarts all will be well again.
    If this procedure does not work, follow steps 1-4 again but on step 5 choose option 4. If this does not work try again but with option 5.
    If none of these procedures work then I am afraid it looks like your hard drive may have become faulty. This will mean you will have to purchase a new one.
    I hope this helps and thank you for using FixYa
    Aug 20, 2010 | Sony Playstation 3 (PS3) Console
    Blu ray discs wont play non blu ray work ok?
    You can try the steps below. Its from PlayStation Forum:
    1. Turn off Playstation®3.
    2. Hold the power button down; the system will turn on and turn off once again.
    3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
    4. When you hear the 2 beeps take finger off power button.
    5. You will be prompted to plug in your controller via USB and then hit the PS button
    6. The Recovery menu will pop up.
    The current Recovery Menu supports:
    • Restart System: Restarts the PLAYSTATION®3 System.
    • Restore Default Settings: Reset all system settings back to default.
    • Restore File System: Checks for corrupt/missing system files.
    • Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
    • Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
    • System Update: Update the PLAYSTATION®3 System
    If the above steps still does not solve the problem, then I think will have to update your Ps3.
    Update your PS3 (in the settings menu the 1st option).
    Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
    well as cookies.
    You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
    But if your problem is not still solved, then maybe you should call sony for further assistance.
    I wish you good luck
    May 16, 2010 | Sony Playstation 3 (PS3) Console
    Wont read disc
    well as cookies.
    May 09, 2010 | Microsoft Xbox 360 Console
    Ps3 wont play coming up with corrupted hard drive. Any suggestions?
    well as cookies.
    I wish you good luck.
    May 03, 2010 | Sony Playstation 3 (PS3) Console
    Wont read the disc .my sony playstation 3 wont read any disc.
    The PS3 has a special Recovery Menu, which you can access in the following way:
    1. Turn off Playstation 3.
    • Restart System: Restarts the PLAYSTATION 3 System.
    • Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
    • System Update: Update the PLAYSTATION 3 System
    From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
    Apr 07, 2010 | Sony Playstation 3 (PS3) Console
    Ps3 wont load games up
    I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
    In case you have the similar problem, you should try the following steps;
    The PS3 has a special Recovery Menu, which you can access in the following way;:
    Select option "Rebuild Database".
    After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
    Nov 18, 2008 | Sony Playstation 3 (PS3) Console
    THE HARD DISK'S FILE SYSTEM IS CORRUPTED AND WILL BE RESTORED
    hold in the power button until you hear 2 beeps. might not work the first time. if no 2 beeps repeat power button again or until 2 beeps. go to restore hard disc and click on it. you will lose anything saved on the hard disc but fixes it 75% of the time. did it myself this morning.
    Nov 15, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    48 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
