Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Salt deposit on washed items
We have  a double-drawer F&P dishwasher and for the past few weeks we've had a problem whereby there are deposits of salt on the items after the wash cycle.
I read the instruction manual as it was a lot cheaper than asking you guys.
Posted on Feb 08, 2009
Why do you have to put salt in my tongtel dishwasher?
Dishwasher salt is used to prevent hard water deposits from spotting dishes and prevents the build up of hard water deposits that can damage the machine.
May 12, 2014 | Asko 1385 Dishwasher
Salt Light
The sensor in the salt chamber isn't reading properly. Try descaling the machine with solution and restarting.
Apr 22, 2012 | Miele Dishwashers
Any thing stainless which gets washed in my dishwasher comes out with rusty spots
Check the items are dishwasher proof, not just the items that are becoming tarnished but other items, main culprits ar cheese graters and garlic presses as these are not suitable for the d/w and will cause deposits on the other items.
There are 4 main reasons
1.Stainless items are left in a damp d/w with salt or acidic food residue.
2.Items are peft for long periods of time in a damp d/w after cycle has finished
3. undissolved powder (particularly if using quick wash) has come into contact with the cutlery.
4. different types of metal have come into contact with each other.
Hope this helps.
Jul 06, 2010 | Dishwashers
Glass and cups coming out with a milky stain on them, no shine at all.
Rub a little vinegar on the surface of an affected item. Does the stain vanish? If so then you have limescale deposits caused by no salt in the machine.
No salt can be an empty dispenser, a faulty dispenser, or using dishwasher tablets/powder without additional supplementary salt in a hard water area. it can also be caused by having the salt dispensing control set too low (on many models it's a lever located adjacent to the dispenser lid).
Mar 15, 2010 | Servis 23 in. M4306 Free-standing...
After a complete cycle now have a milky residue
The milky residue on the glasses is not a residue at all: it is irreversible damage to the glass and is caused by a myriad of microscopic cracks in the glass surface combined with surface etching. Vinegar only works if there's a limescale deposit caused by using too little salt (no salt at all, or the salt dispenser set too low, or just not adding supplementary salt in a hard water area when using dishwasher powders with an in-built salt function)
It can happen to most glassware, but will happen very quickly to lead crystal which is why every single dishwasher I've ever sold or rented out says not to put them in the dishwasher. So called "glass protection" dishwasher powders are a marketing gimmick; all they do is to try and eliminate chlorides from the mix and boost the salt content, but they won't actually stop the damage completely.
Similarly, most advise against putting silverware in the dishwasher. By silverware I specifically mean anything made of silver, plated with silver or electroplated nickel silver (EPNS). Stainless steel is fine though. You might like to read this short article on the subject.
Mar 11, 2010 | Dishwashers
Hello. My dishwasher has been pretty perfect for four years. When my house water softener ran out of salt, I added rinse aid and salt to the dishwasher for the first time. I subsequently added salt to the...
Try cleaning the machine by adding white vinegar to the wash water (before the water-fill procedure finishes). Put your stained dishes and cutlery in with the wash to remove the hard water deposits. The combination of salt and rinse aid may have helped cause this problem. Hope this helps!
Feb 11, 2010 | Dishwashers
Dishes not clean
hi friend,HOW TO GET THE BEST FROM YOUR DISHWASHER
Always follow the manufacturer's instructions and read the directions carefully on detergent, rinse aid and salt packaging.
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaning detergents are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
WHAT ELSE CAN I DO TO GET THE MOST FROM MY DISHWASHER?
Cleaning your machine about once a month will remove any grease and lime scale deposits which can build up on the inside of the machine. Special dishwasher cleaners are available which are used when the machine is empty. These cleaners will often leave a fresh smell in the dishwasher too. If you want to have that fresh smell all the time, use a dishwasher freshener. These are usually supplied as hanging tags, which should be carefully positioned away from any moving arms. A freshener is essential if you load during the day and then run the machine at night.
LOADING
These items can be washed in a dishwasher, with the following guidelines:
Glassware - Any ordinary glassware and ovenware such as Pyrex. Do not wash lead crystal glasses unless they carry a "dishwasher safe" label.
Tableware - Most everyday crockery is safe. Bone china usually has under-glaze decoration and should be safe. Avoid antique or hand-painted and over-glaze decorated items. If in doubt, check with the manufacturer.
Cutlery - Stainless steel and silver cutlery are normally suitable for machine washing, but it pays to rinse off any acidic food before loading to prevent any corrosion and, if possible remove the cutlery immediately after the cycle, to avoid prolonged exposure in a humid atmosphere. Do not mix steel and silver cutlery in the same basket and wash bone or wooden-handled items by hand.
Plastics - Check whether they are dishwasher safe and do not place in the lower rack, where the heating element may affect the plastic during drying.
Pans - Stainless steel is ideal for dishwashers. aluminium can be washed in the machine, but may discolour during the rinsing. If in doubt, remove aluminium pans before the rinse cycle.
Always wash cast iron and wooden handled items by hand
WHY DOES MY MACHINE HAVE A WATER SOFTENER?
If the water is soft (i.e. does not contain calcium particles), the detergent will work more effectively and there will be less streaking on dishes. Hard water can also block the washer jets with lime scale and cause deposits on heating elements, which will reduce the cleaning efficiency, increase electricity costs and shorten the life of the machine. All dishwasher manufacturers (Bosch, Miele, Siemens) and detergent suppliers want you to get the best results from the machine - and soft water is one of the most important factors in achieving this. The way to ensure water remains soft is to regularly top up the reservoir with granular salt.
Three in one salt tablets do not activate the water softener.
HOW MUCH SALT DO I NEED TO ADD?
Your machine may have a float indicator or a warning light to tell you when salt needs adding to the water softener. Often float indicators are difficult to see, and there is no accurate guide as to how much salt you need to add. Quite simply, just add granular salt to the reservoir until it won't take any more!
The softener will use the salt to replenish itself each time you wash. As an approximate guide, you should do a full top up about once a month. If your machine doesn't have a warning light, a good way to remember to check and / or top up is to do it on a regular day of the month (e.g. the first Saturday or the 15th)
CAN I USE ORDINARY TABLE SALT?
No. Table, cooking, rock and sea salts may contain additives that can actually increase water hardness. Also, the fine consistency of some of these salts mean they are likely to clog when wet. Always use granular dishwasher salt because it is very pure and is the right consistency for use in your machine.
Granular salt is the ONLY type of salt that should be used to regenerate the softener. Be aware that some varieties of ‘dishwasher salt’ use Dead Sea salt. This variety may contain minute insoluble organic matter that may adversely affect the resin within your softener over time. If you are in doubt about the origins of the salt, ask the retailer or manufacturer.
WHAT DETERGENT SHOULD I USE?
All modern dishwasher detergents are formulated to work specifically in dishwashers. On no occasion should ordinary washing up liquid be used, as it will cause excess foam, which can result in a leak. If it is accidentally used, sprinkle ordinary salt into the chamber to disperse the resulting suds. Then rinse away the excess salt before using.
There are 3 main types of dishwasher detergent - Powder, liquid or gel and tablets. Which one you choose will be down to personal preference, but most people find tablets very convenient, although using powder is usually more economical and liquids are less abrasive on more delicate items.
WHAT IS RINSE AID?
Rinse Aid is added to a special compartment in the machine and a very small amount is released during the final hot rinse cycle, to reduce the formation of water droplets on crockery etc and so ensures that the water dries away properly and evenly to avoid leaving smears.
Dual action detergent usually contains rinse aid, which is released at a different rate to the cleaning agent and so helps reduce smearing etc without the need to add separate rinse aid. Some 3-in-1 tablets contain an ingredient, which has a 'salt action', which also helps to improve cleaning, but NOTE this is not a substitute for adding salt to the water softener.
The salt action takes place in the cleaning chamber of the machine, but does not actually replenish the water softener. Research has shown that whilst 3-in-1 detergents do clean dishes effectively, their performance is improved by adding salt to the water softener reservoir.
As the performance of machines can vary, as can local water conditions, it is always best to follow your manufacturer’s advice. Some manufacturers advise that if you have unsatisfactory cleaning performance eg white powder residue, poor drying or dirty dishes, then you should return to using three separate products ie detergent, rinse aid and granular salt. Be aware that if you have not been filling the salt reservoir and relying on the salt in 3-in-1 tablets, then it may take a few cycles to re-generate the softener.
hope this helps u
please rate me..................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Dishwashers
Water deposits on glassware
arer you putting salt in the salt container?? in a hard water area, this is essential
Oct 11, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Dishwasher not cleaning
The dishwasher salt response is acceptable for Europeans, but U.S. dishwashers do not have a salt dispenser, nor is dishwasher salt sold in U.S. stores. U.S. consumers should descale their dishwasher using Dishwasher Magic, Lemi-Clean, Lime-A-Way, CLR, or vinegar until scale is removed from the machine, then add a rinse aid to the dispenser, which should prevent future problems. For very hard water, regular, periodic descaling treatments should be done. For the vinegar cleaning, place a full cup (8 oz) of vinegar in the top rack of the dishwasher. This way the vinegar is release throughout the wash cycles, performing a more thorough cleaning.
Sep 13, 2007 | Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
165 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
