Question about IBM NetVista PC Desktop
IBM NetVista 6578-RBG Windows XP hanging
I got this problem when the PC is shut down for more than 2 hours.After 2-3 reboots is working fine.I tried with another HDD, changed BIOS, removed all peripheral devices (CD, DVD, LAN), I have changed even the CPU :/ .... and the motherboard looks good, I also tested the memory and it doing ok...if someone has a clue...pls! :)
  • Thomas F. Schneider May 11, 2010
    I have had this problem in the past. I finally ended up replacing the motherboard. I beleive it is a capasitor that heats up and quits. Just guessing. May not be you problem at all.
  • 58 Answers
It seems, that you should replace motherboard, I've seen this kind of problems in my office, after year or two you won't be able to turn it on at all. In my opinion, it's bad quality capacitor on motherboard.
Any way there is little chance that it cold be bad PSU, but it's really small chance.
Posted on Feb 05, 2009
Manual de servicio de la fuente de poder de computadora IBM Newvista hp m1854f3p
IBM NetVista Type 6838, 6848: Hardware Maintenance LenovoA description for this result is not available because of this site's robots.txt - learn more.
[PDF]Technical Information Manual A20 Type 6269 A40 Types ...
IBM. NetVista™. Technical Information Manual. A20 Type 6269. A40 Types 6568, 6578, 6648. A40p Types 6569, 6579, 6649 ...
Nov 01, 2015 | HP Televison & Video
PC with windows xp professional , on booting , shuts down immediately everesince I uninstalled Nero Dvd writing programme
Reboot your PC and immediately start tapping the F8 key, then choose to start in safe mode. Now click the start button, then click run. Type MSCONFIG and choose startup programs and disable all startup programs and see if it boots ok. If it does you can retype msconfig and one at a time re-enable your startup programs until you find the one that makes your PC hang and reboot, Keep that one turned off after you find it, and re-enable the rest of your startup items.
Aug 30, 2010 | IBM NetVista PC Desktop
Sound drivers of a IBM Netvista
Feb 13, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Ibm netvista shuts down on start up
1. if possible check and see how dusty the system is inside.. used compressed air cans to dust it off.. don't touch any components... watch esd so ground yourself while you're at it
then test
2. you're power supply may be dying: ground yourself to the same ground as the computer (watch for esd) and replace the powersupply.
then test.
the keyboard or controller may be damaged, check for resource conflicts in your bios related with keyboard (make sure no other items are using the same irq's.. check plugs, test with other key board.. replaced motherboard.
random shut down could also mean that the cpu is overheating.. make sure the cpu fan is undusted and working.
Sep 06, 2008 | IBM NetVista PC Desktop
IBM Netvista PCI/PNP Slot 3 Error
I had to remove the old network card and replace it with a new one to resolve the issue.
Jun 18, 2008 | IBM NetVista A40 PC Desktop
Cannot install Drivers for IBM computers
lets start with the ThinkCentre A50 8175. download and install the chipset drivers first.
after you reboot install the network driver.
If this works rate me and we will continue
Jun 03, 2008 | IBM NetVista PC Desktop
How to go to boot settings in IBM 6578-PBU machine
during bootup press del key if not press f10 if not try f1 or f2 or f7. i hope it helps
Apr 17, 2008 | IBM NetVista A40p PC Desktop
Try each of the following: F1 F2 ESC DEL F10
Aug 26, 2007 | IBM NetVista A40 PC Desktop
How to change the boot option in IBM 6578-PBU desktop
I searched for hours for a solution to this. Here it is:
1). Restart your computer, NOT using ctrl - alt - del
2). Press F1 when guided to.
3). When you get into the config menu, select Start Options, then hit enter twice.
There are all the options you need! Cool, huh?
IBM NetVista PC Desktop Logo
370 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
