Question about Epson Stylus 2200 InkJet Photo Printer
Epson 2200 - vertical lines
After the print comes out, there are numerous white vertical lines on my print...probably from the "rollers" picking up the "wet" ink. This printer was purchased used. Any solutions? Thanks!
  • exposito May 23, 2009
    If I don´t use Epson Paper on the 2200 then the rollers grab the ink and let white line on the impresion
    I have not been able to solve it
I don't know if this will help as my printer is a different model (the epson stylus photo r280) but I have been battling the vertical line issue for weeks, ever since getting a new imac. I am printing altered photos from photoshop on epson ultra premium matte photo paper. After trying every conceivable setting, and spending an hour with less than helpful tech support from epson (where they insisted I needed to download new drivers) I just resolved it this morning at last by increasing the dpi setting on the print function to beyond what I would normally use(1440x 1440 rather than what I had been using at 720).
The prints came out great at last!
On my older computer with this same printer the prints came out fine at the lower setting. But for some reason it appears that the higher setting is now necessary to eliminate those dreaded lines.
I hope this helps.
Posted on Jun 05, 2009
I have an Epson cx6000 and I was getting the verticle whites lines. I went to the printer and did some maintenance, Clean the heads, realign the print heads, everything that I could do that I thought would correct the problem. My printer has printed out 2 reports perfectly!
Posted on Feb 02, 2010
Epson stylus Photo 2200
When printing from your pc after selecting print a box will appear with several options including printer preferences. Select this and you will be able to select best photo and the type of paper being used.
Jul 24, 2010 | Epson Stylus 2200 InkJet Photo Printer
Horzontal white lines cut through print and picture copies. When doing head allignment the horozontal bars all have a white gap, 1 through 7. Epson Stylus CX5400
You don't need to do head alignment, because it is for vertical banding in printout. Vertical banding can be minimized by disabling high speed option without doing head alignment. If your printout have horizontal white lines, do check nozzle and head cleaning, or you can minimize white lines by printing in best quality (photo).
Oct 21, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Plain paper is coming out with black lines on it
if the lines on the copies happen only when you use the doc feeder then you have something on the small slot glass if you put the document on the glass and make a copy if there is still a line it is probably the drum
Dec 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Anoterh Vertical Line Problem!
So many questions Vertical lines suggest [you do mean vertical do you - up/and down?] is new one to me try www.fixyourownprinter.com Printing CD's is not a 2200 thing, it is the province of the R series. Printing lables is easy purchase CD labels and suitable CD print software - A kit including labels software and label applicator is available at many computer stores Other labels- download the Avery-Dennison free lable software.
Aug 01, 2007 | Epson Stylus 2200 InkJet Photo Printer
Vertical bars through printout
Look closely at the marks on the print, and in particular the distance between the lines. Now look into the printer through the paper exit path. Take note of the metal star wheels. Does the distance between the lines match that of the distance between the star wheels? If so then the plate that the start wheels are mounted into may have dropped. You can remedy this by gently lifting the plate back up by hand. Set the machine as if you where going to print a CD and simply lift the start wheel plate at each end. Do not force it or apply too much pressure. Ease it up and then try it again. If it needs more adjustment repeat and check again. If the marks appear to be caused bu ink on one set of rollers or another, pass a really thick piece of card (like off the back of an A4 refill pad) through the paper path. Spray the rollers with a cleaning solution or windowlene (windex) and then pass the card through. This will help to clean off any ink. Again you can repeat this process as neccessary. Let us know if this helps before rating - if it does not I may have more info
Jul 27, 2007 | Epson Stylus 2200 InkJet Photo Printer
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus 2200 InkJet Photo Printer Logo
1,227 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
