Question about Fujitsu Siemens Lifebook N5010 Notebook
I want to on wireless( Wlan )on kaptop fujitsu siemens kindly send me the procedure and itemise the key on the keyboard to use. thanks Aimuan A. Harrison
How do i switch on wireless capability using my keyboard function keys i have a fujitsu siemens
On the top row of keys of your keyboard (usually the F1 - F12 keys) there should be a key that contains either a wireless signal (an antenna with "signal waves" coming out of it) or a button that says 'Wifi' on it. Regardless to enable it this way in most cases you must have the Function key held in before you press the wireless button. The function key is a key on the bottom of your keyboard that says: 'Fn'
Thanks and please rate if this helps you!
Mar 29, 2011 | Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
I need WLAN driver for my AMILO pro v2010 laptop.
Type in Support Fujitsu in internet explorer go to downloads and put in your laptop serial number, it will list all the drivers for the V2010 download and install the WLAN driver, once the driver is installed the wireless card should then show any close by wireless networks. This is a free Fujitsu service,
Hope this helps.
Jun 13, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
How do i turn my wirless connection on my fijitsu siemens amilo pro
Gateway Laptop ---- Switch on side and then Fn / F2
Apr 02, 2010 | AT&T Siemens S46 GSM Cellular Phone
No external wireless switch - how do I turn on wireless function on a fujitsu siemens laptop ?
I don't know that particular model, but in most laptops without a switch, there is a key on the keyboard that has a wireless little logo. The key usually works by pressing it simultaneously with the "f'n' (function) key. The wireless key is usually located at the first row of keys (the function keys, F1, F2 and so on). Hope that helps
Fred
Nov 26, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Replace keyboard for fujitsu siemens amilo pro v3515
Hello Den,
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
Best luck
Nov 30, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Siemens Amilo Pro V2000D - No Internet?!?!?!?
http://support.fujitsu-siemens.com/com/support/index.html
and then into the search box AMILO Pro V2000
and you should come to drivers and download section press that one and then select youre operating system
and then you choose panel and download the launch manager which with you can make the wlan to start with system..Huh..FINLAND RULES
Jan 30, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu siemens laptop
press the fn key and the f2 key, the fn key should be at the bottom of your keyboard, normally on the far left side.
Nov 12, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens Lifebook N5010 Notebook Logo
359 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
