In my computer it says USB device not recognized
One day it fell down and i went on it by my bike
  • 3 Answers
Uninstall your drivers and then install again.
{NZA}
Posted on Feb 09, 2009
My external hard drive fell down twice on a carpeted floor. Now, I cannot open it with whatever USB cable I use. The computer can recognize the device, but it cannot read the files in it when I access it...
If the drive can be recognized by the cmos there is hope. Remove the drive from the case and plug it in directly to your computer. It should be recognized by the cmos and should be accepted as a secondary drive when your master drive boots up. Then use windows explorer to get into the drive and transfer the files out of it. Remember that if this works for you the issue might just be with the case electronics. If drive is recognized but you cannot see the files, you can get recovery freeware on the web to do the deed.
Sep 09, 2017 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
I have a Craig mp4 .. but I'm trying to use it but i do not how .. because when i connect it to the computer it is not recognized by the computer please help me
Hi, Are you getting a "USB device not recognized" error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
usb device not recognized
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn't work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn't work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an "Unknown Device".
unknown usb device
So how did I finally fix the problem? Well, apparently it's a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
Have a nice day...
Mar 02, 2011 | Audio Players & Recorders
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
USB Mini Optical Mouse - Model: M409 company Enter not recognized
go to device amanger then uninstall all usb drivers from computer then restart the computrer then it autoinstall all usb drivers.
tehn connect your usb mouse cable to computer try all usb port then if problem arise then your mouse usb chip has issue.
Thanks for using fixya.
Please rate solution if it helps.
Jul 24, 2009 | Computers & Internet
My EasyCAP doesnt work!~
hi there,
if your usb port is not recognized by your computer anything you want to install in your usb will not function,try to check your usb on device maneger and updated your driver through website,
if your game controler is not recognized by your computer go to control panel click game controler and add your device follow the wisard instruction and install your controler,controler is plug and play device.have a nice day,regards
Jul 10, 2009 | DekCell (CPA-1040)
Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
Mar 05, 2008 | Belkin BLKF5U201 USB Peripheral...
Computer does not recognize player when connected
i had the same problem with my c240..my computer would not recognize that i had connected anything..so i went to settings on the player scrolled down to USB option press ok and changed the setting to MSC instead of auto detect ..i reconnected it and the player came up immediately ..worked for me hope it does for the rest of you..{if anyone knows how to delete songs let me know..thks}
Nov 10, 2007 | SanDisk Sansa c240 MP3 Player
Mi USB device is no longe recognized
Well the fact that it says it can't load the device but sees it, is a pretty good sign actually...first off check the drivers for the device... good luck
Aug 25, 2007 | Encore ENUWI-G2 802.11G WIRELESS USB 2.0...
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
