Question about Hotpoint WMA40 Front Load Washer
Aquarius 1200 WM64 - machine does not start
The washing machine has suddenly stopped working. The start light does not come on, and I have changed the fuse in the plug but still does not start. I have no manual. I assume it is somewhere in the electrics but have no idea where to start.
  • Hotpoint Master
  • 19,396 Answers
If you already replaced the fuse, next part to inspect is the control board behind the timer.
If that is ok, check the wiring harness, the socket and the power cord.
Posted on Feb 03, 2009
Zanussi 1200 aquacycle fx1265w
Either it not getting water, or the motor brushes are worn out.
Sam
Jun 21, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
I am looking for an instruction manual for a Hotpoint Aquarius 1200 WM64 and I can not find one online to download. Can you help?
Hi.
Please click on the link below to open the owners manual for Hotpoint Aquarius 1200 VM64 in PDF format:
Hotmpoint WM64- Washing Machine
Regards.
Ginko
Sep 13, 2011 | Hotpoint Washing Machines
I got a Hotpoint Aquarius Extra Washer Dryer WD64 GB 1200, it worked before and suddenly did not work yesterday, when i supply the power and close the door properly and start the programme, the light is...
most common reason for what you are describing is a faulty door lock part no. 1602390.
easily fitted by undoing door seal retainer, removing two screws holding on door lock and then just change over wire for wire.(only 3 wires).
this should get you going
Jul 07, 2011 | Washing Machines
We want to know if we can run the washer (hotpint aquarius 1200 wm64) just on the cold inlet?
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 04, 2011 | Washing Machines
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA40 Front Load Washer Logo
367 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
