How to connect sharp cd-ba 1700 to pc?
I've got the sharp cd-ba 1700 and i want to connect it to the PC if it possible.
    Genius:
  • 1,550 Answers
If your sistem got auxiliar option,you can connect your pc through the earphones output of the pc to the auxiliary inputs on the shelf sistem they are a cable named 3.5mm to rca outputs to fit that connection gfood luck
Posted on Feb 11, 2009
Compaq armada 1700-when powering the system the following error appears "Error loading operating ststem"
There is a good possibility that the hard disk drive may be failing, so if you can try running diagnostics and see if you get a failure on the hard drive.
If you can't run diagnostics, then boot to your Windows CD, press R for recovery console, then at the command prompt run the command CHKDSK /R see if you get any errors on files.
If that doesn't resolve, then boot to the windows CD press enter instead of R and repair windows.
If that still fails, then the hard drive is likely bad
Aug 20, 2011 | Compaq Armada 1700 Notebook
My sharp cd-ba 1700,has protect on screen.how do i remove.thanks
The most common failure is of the internal Amp IC for these units. See the link below for a generic explanation of protect mode. I believe that the amp-pacs for these are still available and are in the $45 range.
Dan
Link: http://www.fixya.com/support/r5390728-protector_means
Oct 01, 2010 | Sharp Audio Players & Recorders
Sharp cd-bp1200w cd carriage will not open power is ok display ok . cds locked inside!
On my sharp CD-BA 1200 most cd's do not run. It is the problem that has recently occured. Kindly suggest solution.
Mar 14, 2010 | Sharp Multi-System Mini Component System...
How i install window in MM10-PC sharp laptop
Installing windows in Personal Computer are needed Bootable at CD/DVD Drive. Your problem is you don't have any CD/DVD Drive.
Use a Portable External CD/DVD Drive.
It's available in the market.
Aug 23, 2009 | Sharp Actius MM10 Notebook
How to set clock on Sharp XL 1700 stereo
When the system is off take the remote and press the clock function. After the system lights up press and hold the memory button on the remote. Then press preset up or down to change hour (cycle through 12 hours to change AM PM). Then press the memory button again to change to minutes and repeat.
Jul 30, 2009 | Sharp XL-1700 CD Shelf System
Dell Studio 1700 - dvd/cd will not work
Hello
i have the same laptop and you have to install it properly because vista needs time
Thanks
May 24, 2009 | Dell Studio 1737 Laptop
My audio system says protect on display
Hi Jean,
Without a brand and a model, best that I can provide are generic possibilities:
1. unplug the unit from the mains for a couple of hours. This is supposedly to reset most systems; and/or
2. check the speaker wires and make sure none of any bare wires are touching each other.
If your concern has not been corrected after completion of the above procedures, pls post back brand and model.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Audio Players & Recorders
Sharp sd nx10_out signal trouble
Try all of the spaekers on the channel you know works. If all are fine, swap the speaker lines to test them. Is the input a DVD player on RCA cables? A bad signal cable from a component can be a source for problem. Connect the speakers directly to the amp(if possible) bypassing the sub box. If all works without the box, suspect bad crossover or in the self-powered boxes a bad amp.
Jun 22, 2007 | Sharp SD-NX10 CD Shelf System
189 people viewed this question
 Grubhead
Grubhead
