Question about Zanussi ZWF1440 Front Load Washer
Zanussi washing machine won't start E10, E40 & E50 at times
Hi, my wife found the zwf1440W stopped with E10 message. She checked filter - not bad so cleaned & reassembled - still wouldn't work. But on leaving emergency hose open as permanent gravity drain (to bowl), I am told the machine would spin (but it won't now).
We get one click when we start drain (or indeed any) programme - which runs for maybe 30 seconds (with no pumping), then 2 clicks as programme stops.
I have now:
- Checked outflow hose and drain connection - OK
- Checked if drain pump impeller moved when drain programme on (filter unscrewed) - No
- Disonnected power leads from drain pump, and attached to multi-meter - reads 120v when drain programme running (odd, why not 230v?).
- Phoned local parts supplier - agreed pump was likely problem.
- Removed pump (Askoll, label said 230-240v). Didn't check winding resistance, but put mains across it (to check again if it would turn) - bang! - (now open circuit!)
- Fitted new pump - still no pumping.
- Tried manual filling and emergency draining several times, getting various E40 and E50 codes.
- Turned off and went to bed.
- Next day, No E-codes, but still no pumping. Tried manual filling and siphon draining (through proper outflow pipe into bowl). Did this while drain and spin programmes were on, and would get one click when programme started, and 2 clicks when siphoning over, but still no pump action (and the spin cycle did not move on to next phase).
Can anyone suggest what to do next. Would get service man to look at it, but wife says call out charge wasted if machine is scrap (it is probably 5-6 years old) - just put the money towards new machine.
  • Anonymous Mar 22, 2014
    already changed drain pump what should I try next
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
Posted on Feb 04, 2009
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Mar 11, 2017 | Electrolux Washing Machines
Error code e71
Blocked filter or faulty pump
Jan 04, 2018 | Zanussi ZWF1440 Front Load Washer
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
E10 error message
I have had the same problem on an AEG. The problem it refers to is that there is not enough water entering the machine. Either the water pressure is too low or there is something blocking pipes/filters. Hope this helps
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi iz 161s
e10 indicates a problem with water supply
Oct 12, 2007 | Zanussi IZ161S Front Load Washer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZWF1440 Front Load Washer Logo
914 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
