Question about Acer TravelMate 2300 Notebook
System not powering on in acer tm2300 - Acer TravelMate 2300 Notebook
Hello
Posted on Feb 03, 2009
My Acer Aspier netbook will not load past the windows screen just keeps reseting
The windows operating system may be corrupted. Suggest you restore it as the simplest solution.
The Acer Aspire One has a hidden partition on its hard disk drive that contains installation images to restore the system operating system, applications and drivers to the factory defaults. Press Alt and F10 key together while the Acer logo is displaying as the system is powering up. This should enter Acer eRecovery Management. Follow the onscreen instructions to do the recovery.
Feb 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One 521 does not boot. When holding down power button - battery charging light goes out and when I hold ear near power connector, I hear clicking noise every 2 seconds. Have tried taking...
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. In order to recover the system using Acer Recovery Media, an external optical disc drive is required.
  2. When the Acer logo appears on the screen, press the F2 key repeatedly.
  3. Press the Left Arrow key until you've selected Boot.
  4. Ensure that the external optical drive is plugged into a USB port.
  5. Refer to on screen instructions to set the first device to USB CDROM.
  6. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  7. Close the CD-ROM tray.
  8. Press the F10 key and then the Enter key to save the changes and restart the netbook.
  9. The computer will boot from the Acer Recovery Media
  10. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  11. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media you may purchase recovery media online. If your computer is unable to run the Acer Recovery process, or errors occur during recovery please contact Acer Support.
Dec 12, 2010 | Acer Aspire One PC Notebook
How do i restore my acer laptop to factory
Select models have the ability to have the operating system reinstalled from a hidden drive built into the netbook. To start the Acer eRecovery:
  1. Tap the Alt and F10 keys togther during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. When prompted with a boot screen, hit the Enter key.
  3. After the Acer eRecovery program has loaded follow the prompts to reinstall the operating system.
If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from Acer Recovery Media. In order to recover the system using Acer Recovery Media an external optical disc drive is required.
  1. Press F2 to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed).
  2. Arrow over to "Boot".
  3. Ensure that the external optical drive is plugged into a USB port.
  4. Refer to on screen instructions to set the first device to "USB CDROM".
  5. Press the CD-ROM drive eject button and insert the System CD.
  6. Close the CD-ROM tray.
  7. Press "F10", then press "Enter" to save the changes and reboot the system.
  8. The netbook will boot from the Acer Recovery Media, follow the prompts to reinstall the operating system.
Please rate!
B_R
Jan 08, 2010 | Acer Aspire One Netbook 8.9" Notebook
My laptop aspire 7520 when powered on the fan spins for 5sec and turns itself off
System usually during POST (Power on Self test) does that kind of thing. if the power supply doesn't give enough power to start the system,then it restart again and again.
If the problem is not due to Power supply,it's usually the motherboard failure.
Get your system to a nearest Acer Servicing Center and let them check.
Jan 02, 2010 | Acer Aspire One PC Notebook
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Won't Power On!
My brother had the same problem with his machine. On doing some research online I came across this site:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3390#results
It gave the following 2 solutions to the problem. The first one workedfor a while but then we had to try the second and this seems to havesolved the problem.
Solution 1
ssue
No Power or Will not boot
Solution
If the unit will not turn on and has no power:
  1. Verify that the power cord is plugged both into the unit and an electrical socket.
  2. If it is plugged into a power strip or surge protector verify that the power strip or surge protector is turned on.
  3. Try another power outlet.
  4. Unplugthe power cable from the unit, hold the power button on the unit downfor 30 seconds. Release the power button and plug the power cord backinto the unit. Try to turn it back on.
If the unit has power but does not boot into Windows:
  1. Turn the unit off and unplug the power cord from the unit.
  2. Hold the power button on the unit down for 30 seconds.
  3. Release the power button and plug the power cord back into the unit.
  4. Turn the unit on.
Solution 2
Issue
Recovery media and Restoring a system to factory load
Solution
Acersystems ship with eRecovery Managr, which facilitates the creation ofRecovery media (CDs or DVDs) so the system may be restored to theoriginal load in the event of unrecoverable issues.
How to Make Recovery Media
  1. Click on Start, then All Programs, then Acer Empowering Technology.
  2. Click on Acer eRecovery Management.
  3. If prompted to create a password, create a password and hint.
    Do not lose this password.
    If asked for a password, enter the previously set password.
  4. When the Acer eRecovery Management loads, click the button labeled Burn Disc.
  5. Click Create Factory default disc.
  6. Follow the instructions and put in the required Blank DVD or Blank CD media to make a set of Recovery Media Discs.
How to Recover your system from within Windows
  3. If prompted to create a password, create the password and hint
  4. When the Acer eRecovery Management loads click the button labeled Restore.
  5. Click on Restore system to factory default.
  6. The unit will restart and start the restore.
    It should state "Please wait a moment..." with the Acer logo in the upper left hand corner.
  7. At the eRecovery Management menu it will ask you how to restore.
    Click on the restore option you would like to use.
How to recovery your system from bootup
  1. Locate the Alt key, to the left of the space bar, and F10, on the top row of keys.
  2. Power the system on.
  3. When the system is powered on, tap the Alt and F10 keys together at the same time when the Acer splash screen appears.
  4. At the eRecovery Management menu it will ask you how to restore.
  5. Click on the restore option you would like to use.
We used the recovery from bootup version.
I hope this helps you.
Oct 20, 2008 | Acer Aspire L100 PC Desktop
Aspire 5500 power problems . -
There has been many problems with the svc pck 3. Mostly consisting of software conflicts that weren't there before the update. Uninstall svc pck 3 and see if that cures it.
Jun 18, 2008 | Acer Aspire 5500 5570-4421 Laptop
Computers & Internet Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
