Question about Lexmark X1150 All-In-One InkJet Printer
Printer will not print
The computer tells me to close the lid even though the lid is properly closed.
i had trouble replacing an ink catridge and dislodged the lid from its back left hand mount.
i replaced it but suspect that i have maybe damaged a sensor or something
    Guru:
  • 558 Answers
It might be the carriage not fitted or get loosened when you place cartridge in it. So needs to check its carriage, roller and any screws and joints hanging the cartridge and roller.
Posted on Feb 03, 2009
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
I can't close the lid on hp deskjet 5652 printer
try removing all ink and one by one just make sure it is all the way in securely. if that does not help its most likely you are closing the doornto fast or on an angle which prevents it from closing properly. hope this helps.
Apr 19, 2012 | HP DeskJet 5652 InkJet Printer
Cartridge is in but printer does not reconize it. How can I correct this? Was told need a new carriage, however printer is barely used. Will not pay any money to fix this problem. Will give printer...
Hello;
Try Reseatting the Catridges, follow the steps
* Switch on the unit and open the lid on the top cover
* Remove the Catridges from the printer
* Then just re-install the Catridges
* Then just close the unit lid or top cover
* After closing, cycle the power of the device by turning of the device for a few seconds
* Turn the printer back on
* Try printing a test page
If the before solution did not work, try the next one.
Wipe out the Catridge contacts
* Turn the unit on and open the lid or top cover
* Remove the Catridges,
* Use a clean cloth or a clean coffee filter to wipe the catridge. Wipe the catridge so briskly
to clear the waxy lubricants from the gold contacts.
* The contacts inside the printer may also require the cleaning. Use the clean cloth to wipe
from top to bottom of the contacts.
* Re-install the catridges and close the printers lid or top cover.
* Then try printing the test page.
If even the second solution didn't work try the last solution down
Perform a hard reset on the device
* Verify the unit is power on.
* Then unplug the power cord from the printer
* Wait 30 seconds
* Press and hold the power button in the front panel
* Plug the power cord back into the printer
* Open the top lid or top cover and reinstall the catridges
* Turn the device on
* Print a test page.
If the problem is unsolved, try replacing a new catridge.
Nov 03, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I have an HP PHOTOSMART C4680!On the screen it apears "Cartrigde problem" and the button is blinking!What can I do to fix the problem?
1.Remove the ink catridge
2.Replace properly
3.try to print
4.if even same problem will be occured then replace with new catridge.
Note: Hp printer come along with a software cd.it has the driver for printer,troubleshooting and maintenence software.in the trouble shooting guide will help to removes and replaces the catridge properly.Also a Quick start guide(A printed sheet) also can help.
5. if Even the problem not solved then unsqurew the printer squrews carefully ,
6.look at the mechanisim if any damaged
7.look any Data cable or Power cable may be damaged (Cables are looking like a white color mica ribbon)
Thank u sir ... All The Best....
Apr 22, 2010 | Office Equipment & Supplies
How to change ink cartridge
There should be a Lid you can lift up (where the paper comes out after being printed on) and when you lift that up you will see the ink cartridge move to the middle, Where you can push the open switch and replace the ink catridge. After the ink is replaced, lock the ink cartridge holder, and close the lid. You then should be ready to print.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 24, 2010 | Brother MFC-5440CN All-In-One InkJet...
How do you change ink
To Change the ink Cartridge please follow the instructions as under:
  1. Turn on your computer and open the front cover of your printer.
  2. The Cartridges will automatically come in center.
  3. Pull up the holder lid and carefully remove the print cartridge on a 60 degree angle.
  4. Press the ink cartridges into the slots and listen for a clicking noise after the insertion
  5. Remove the tape from your new print cartridge and carefully put it in on a 60 degree angle, snap the lid back in place. close the printer.
  6. Open the printer software in your computer, click the tab maintenance and click install a new cartridge and click the number. Print an alignment page.That's it !
Thank you for using Fixya
Oct 08, 2009 | Lexmark X4550 Multifunction Wireless Color...
Replaced Yellow Cartridge, Red light on, close lid, not working,
Hi ...
I would suggest that you follow the below stesp to install the ink tank ..
. Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
Note: If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2. Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3. Remove the ink tank whose lamp is flashing fast or is off.
Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Caution: Handle ink tanks carefully to avoid staining clothing or the surrounding area. Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
Note: Be sure to replace ink tanks one by one when replacing more than one ink tank.
4. Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
Unpack the new ink tank and completely pull off the orange tape. Then, remove the film. Remove the orange protective cap from the bottom of the ink tank and discard it.
Important:
  • Be sure to remove the clear film from the ink tank in the exact order shown in step 4, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
  • Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
  • Do not re-attach the protective cap once you have removed it.
  • Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
  • Ink on the removed protective cap may stain your clothes and hands.
  • Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5. Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important: Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6. Close the Inner Cover.
Note: Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7. Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
  • The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
  • To maintain optimal print quality, use an ink tank within six months of first use.
  • Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
  • Color ink consumption may occur even when black-and-white or gray scale printing is specified.
    Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
  • When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Ink cartridge light is blinking, I replaced the #45 ink cartridge
What's the printer's model. The print heads may need to be cleaned.
Dec 28, 2008 | HP DeskJet 6122 InkJet Printer
Hp 5550 blinking
remove the 2 ink catridge and cover it back you will see only catridge error light peeping. off it and on it back then put the 2 catridge back i hope this will solve your problem. from .
Aug 10, 2007 | HP DeskJet 5550 InkJet Printer
It thinks the ink cartridge is not installed, but it is
It's because you touched the connection side of the cartidge. Clean it with some contact cleaner(or surgical sprit)and let it dry.If possible clean the printer side of catridge contact.After both are dried well, put the catridge back.it must work.
Aug 03, 2007 | Canon PIXMA iP90 Mobile Printer
Lexmark X1150 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
