Question about ASUS P4S800-MX Motherboard
Upgrade to 1g RAM
Have bought Kingston KVR400X64C3A/1G
1GB PC3200 CL3 184-pin DIMM.
Computer will not work with above RAM.
Will return to shop.
Have 256MB, need 1GB for game play.
At 67 yrs I'm trying to keep memory working.
Hope you can help with problem.
I live Perth Western Australia, and do not know of any
suitable dealers?
Thanks,
Robin Bodilly.
  • Anonymous Feb 04, 2009
    HI Nic,
    Motherboard ASUS X series P4S800 - MX - UAY6Z.
    Tried Kingston PC3200 1GB 400M DDR no luck.
    robi
  • Nicolas
    Nicolas May 11, 2010
    If you tell me the name and model of your motherboard i will try to
    guide you to buy a correct memostick fot your pc.
    Nic
  • 1,602 Answers
Take your old ram with you when you buy the new one, also you new to know if you new duel channal memory
or parity memory
or edo or non edo ram
most of the information will be provided by the vender of the computer. hp tell you everything it is , duel channel, edo, non edo, parity and non parity memory than take the information you have on hand to fry electonics store or online to egg head.
pay alot less for the same memory they were going to charge you and arm and leg for..
rod is the candymangandy
Posted on Feb 03, 2009
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Nov 16, 2010 | Intel D102GGC2 Motherboard
2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Jun 02, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
Kingston Hyperx memory suitable for dell dimension 2400?
go to your motherboard web site check with them to see if it right or not trust only board company is the best jim
Apr 17, 2009 | Kingston HyperX 512MB PC3000 DDR DIMM...
Added 2g to a dell dimension 3000, only 1g recognized
Dell has a really good support site. You log on, enter your service tag number (on the top of side of your PC) and they will tell you exactly how much ram you support, the type of ram needed and how many slots it has. If it was a matching pair then it should be working, unseat it and reseat it, it may not be in all the way. If still don't show then put it back in the old computer and see if it reads it. If not then the RAM stick got damaged during the move. But no doubt you should be able to handle more that 1GB of RAM. Good Luck, let me know if you have any questions.
Please rate this solution.
Apr 13, 2009 | Dell Dimension 3000 PC Desktop
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Memory upgrade
Here is what your board can handle according to Asus. Memory 2 x 184-pin DIMM sockets support max. 2 GB DDR 400/333 non-ECC memory Hope this halps & please rate this answer fixya. Thanks.
Feb 02, 2009 | ASUS P5RD1-VM Motherboard
Installed new RAM, PC would not boot up.
Will the PC boot? It may just be loose. Try it again. The PC may not boot if it does'nt recognize the memory.
Sep 19, 2008 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
ASUS P4S800-MX Motherboard Logo
130 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
