Question about Sebo Automatic X1 Bagged Upright Vacuum
Replace power cable on Sebo X4 vacuum claenaer
Purchased replacement Sebo power cable, but having removed the crosshead screw from the aluminum handle shaft cannot figure out how to gain access as the plastic handle will not withdraw from the metal shaft. Is there a trick to dismantle the handle assembly?
  • awmw Feb 05, 2009
    Thanks for this managed to sort the problem - was exactly as you said.
  • 3 Answers
From memory the plastic part slides up a little, enough for you to access the wiring. I'll try and have look at work tomorrow.
Warning though! you need to do this work with the handle laying flat, the screw hole upwards - it may be already too late as there is a nut that slides away and can be tricky to get back
Posted on Feb 04, 2009
Orange spring will no longer hold cleaner in upright position.
You may need a replacement spring just a guess so here's the list of replacement parts with prices best of luck! Spare Parts AUTOMATIC X4 SEBO Vacuums Online Store
Jan 07, 2016 | Sebo Automatic X4 Extra Upright Vacuum...
How to remove retention clip on sebo x4 to repair electric cable
Check out Espares video on how to repair and replace cable on the SEBO X1. It is the same machine as the X4, only difference is a different motor and cosmetic differences. I rely on this video and a few of the others that this company have done on You Tube for SEBO repairs.
Don't forget to rate, thanks.
May 20, 2015 | Sebo X4 Bagged Upright Vacuum
How do I replace the front bottom plate on my Sebo X4 Extra vacuum cleaner, this is the metal/plastic plate on the front base of the bottom of the cleaner (no visible fixings)
With the power head cover removed, you will see tabs on the inside of the chassis inline with the front bottom plate. Simply pinch the tabs with some needle nose pliers and push. I have included a link to the parts list as well as the front bottom plate. You will see by the picture what those tabs look like and how to remove the front bottom plate. 5411 HG Front Bottom Plate Windsor Sensor S12 XP12 SR12 86138280 allstar... http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Dec 09, 2014 | Sebo X4 Extra Bagged Upright Vacuum
My sebo x4 bagged hoover is losing power, what could the problem be
Is it a Sebo , or is it a Hoover. It can't be both . "losing power" ??? Motor comes on and off ? or stops picking up ? Be more specific please.
Oct 20, 2013 | Sebo X4 Bagged Upright Vacuum
Hi, I've just had my Sebo X4 back from being repaired (motor was growling so Sebo replaced it FOC under warranty) however, the replacement motor is 1000 watts. I queried this with Sebo, as they c
Watt= volts x amps So what are you losing? Not much really. Should they replace it with the same motor? Possibly, but you got a free motor out of them. To be honest I think you're splitting hairs on this one. The difference in how much cleaning that sebo will do with one motor vs the other is beyond minimal. The aggressive brushes on that vacuum do 95% of the carpet cleaning and both motors will have no problem turning it at sufficient speed. As far as suction goes I'd be amazed if it was even a noticeable difference. That's an amazing vacuum you bought, I wouldn't worry about it and go on with life.
Good Luck
The Vac Dr.
Nov 12, 2012 | Sebo X4 Bagged Upright Vacuum
My sebo x4 extra does not start. There is power but no warning lights are flashing. When I turn the vacuum on there is a continual clicking/buzzing sound.
Hi.
Eeither motor or servo motor with gear box is seized. Testing is done energizing the motor. Test and repair must be done by a technician. Call the number listed on the owners manual to contact a qualified repairer.
See: Parts List and schematics SEBO X4
Jul 31, 2010 | Sebo X4 Bagged Upright Vacuum
I want to release flex from sebo x4 vacuum cleaner to cut back...
On the underside of the handle, there's a small screw close to where the metal and plastic parts join. Undo this screw. This will allow you to pull the plastic part out of the metal part - not very far, but just far enough so that you can separate the plastic part into two halves lengthways. That gives you access to the switch, and you should find the rewiring job and reassembly straight forward from there on.
I hope this helps. If you need more, just post a reply and I'll get back to you as soon as I can. I do value feedback, so please remember to rate this answer.
Mar 06, 2010 | Sebo X4 Bagged Upright Vacuum
I need to know how to repalce the drive belt in a Sebo upright cl
Thanks to its automatic height-adjust feature, the Sebo X4 has two drive belts, one from the motor to the height-adjust sensor, and another from that sensor to the brush roller. To access them,first remove the base from the handle, undo the four recessed screws on the underside of the base, then turn it over and lift off the cover. You will then see the belts. The rest should be obvious (it's a while since I've done one of these, but I think you may have to loosen the screws holding the height-adjust sensor before you can slip the belt off).
I hope this helps. Any further problem, just re-post here and I'll do my best. Good luck!
Feb 01, 2009 | Sebo Air belt K3 Bagged Canister Vacuum
Brand new sebo x4 won't turn on. It has never been used.
No, and being under Warrenty, take it back to where you bought it and have it looked at. You will void the Warrenty if you do anything to it. One thing to that you can check is make sure that the handle is all the way inserted and locked. The vac. is shipped with the handle not installed and will not turn on if not all the way inserted.
Jan 06, 2008 | Sebo X4 Bagged Upright Vacuum
Sebo Automatic X1 Bagged Upright Vacuum Logo
638 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
