Question about Watches
I have a dolce gabbana watch and i cannot open it, there is no where i can see on the back to flip the outside casing to open it.
  • vpeters10482 Feb 03, 2009
    no definitely not.....
  • 2,334 Answers
There is the groove or the lip on the back, but it might be very tiny. Get an eyeglass and examine caseback very carefully all around and you will find it.
Do not forget to rate, please.
Posted on Feb 03, 2009
Need a new leather strap. Wheere to find?
I'm sure there's universal straps u can get but original strap keeps the value
Jun 14, 2012 | DG Dolce & Gabbana Cream DW0058 Watch for...
How do you set the time on a dolce & gabbana eden
I have looked at their web site and although there are a number of watches listed, I couldn't find the one you mentioned.
I suggest that you click on the link below to contact them and ask for help.
http://store.dolcegabbana.com/cms/help/contactform.asp?tskay=436A8784
(Before you do, there must be some method of adjusting the watch and I have seen ones where the adjuster is hidden in the watch strap area. Look carefully under the strap fixings and you may see a push button let into the body, which will need a small probe to operate. There might be two (one on the opposite side). If yours is an electronic watch then one button (mode) will for entering the setting mode and the other to change the setting. When setting is complete, press the mode button to return to normal operation.
May 06, 2011 | Watches
I broken braslet by d &g wathes were i need to fix it
I strongly recommend visiting or contacting your local Certified Master Horologist to repair or replace the band, link, or clasp that may be damaged. They usually can either repair it for you or order the parts from D&G for you and fix it on site for you.
Feb 23, 2011 | DG D&G Dolce & Gabbana Caterpillar...
How do you open the back of a bulova watch
You need a special tool called a case opener, if you flip the watch over you should see 6 square slots on the outer rim, this means that the back case is screwed on and probably has a water proof seal, keep in mind there are different sizes. I suggest you check ebay for watch tools, you might find what you are looking for.
Dec 17, 2010 | Bulova Men's Watch
How long does the battery of a D&G TIME red watch last? I think my mom bought my watch a couple of months ago and was given to me only last night. the problem is that nothing is working or moving. i...
Thank you for contacting FixYa.
It seems to me to be the battery. Batteries vary from watch to watch but the norm is 2 years. But you never know how long a watch has sat on the shelf of a store, etc.
I would take to a local jeweler to have them test the battery in your watch.
Hope that helps.
Jewel
Aug 26, 2010 | Advance D&G Dolce & Gabbana d #3719740289...
On a rolex watch, does it have to have the serial
Numbers on case back are inside. Number on case is outside, located between lugs. You need to remove bracelet to see it. Rate me, plz.
Apr 26, 2010 | Rolex Daytona 116520 Wrist Watch
Cannot open clasp prestige replica rolex
1)Unscrew the crown until it pops out, the same way you would unscrew the crown to change the time on the watch.
2)Place the watch case opener in the notches around the outside of the back of the watch case. You have to use a watch case opener made for Rolex watches to open the watch. Once the case opener is in place, twist it and the back will pop open.
3)Use a mini screwdriver to loosen a tiny screw on the inside of the watch located near the stem. You do not need to unscrew fully--only loosen it.
4)Pull the crown straight out. The crown and stem should come out easily.
To open the back of the watch
1)Purchase a Rolex watch back opener set, if you do not already have one. This set is able to open and close any size of Rolex case.
2)Match the size of your Rolex case with the same size of grooved metal die from the tool set.
3)Put the metal die on the grooves on the back of the watch case.
4)Turn the die to remove the case.
5)Remove the rubber gasket.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Bulova Watch
Watches Logo
361 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
