What ntfs? - Computers & Internet
  • 565 Answers
NTFS stands for New Technology File System, you'll see it a lot with Windows XP, it's just the file system that your computer can use. Technician's prefer it to FAT 32 because it is more secure.
Here are some links so you can read all about NT File Systems:
http://www.aumha.org/win5/a/ntfs.php
http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Posted on Feb 03, 2009
Online ups having not backup
Hetman NTFS Recovery recovers files and folders from all types of hard drives formatted with NTFS, including SSD drives and external storage. The NTFS file recovery tool can perform a simple undelete operation to recover deleted files or perform a comprehensive data recovery procedure, extracting all files and folders from the damaged NTFS volume complete with the original folder structure.
Hetman NTFS Recovery recognizes and recovers NTFS alternate data streams, and supports the recovery of compressed and encrypted files. The NTFS recovery tool works in all 32-bit and 64-bit versions of Windows including those that do not natively support the NTFS file system.
Key features
• Offers the best value to users of modern versions of Windows (Windows XP and up) thanks to exclusive support for the FAT file system;
• Unformat formatted partitions and restore original volumes from repartitioned hard drives;
• Undeletes all types of files including pictures, music, videos, documents etc.;
• Recovers data from formatted, corrupted and inaccessible NTFS disks and SSD drives;
• Restores files from formatted NTFS volumes and repartitioned disks;
• Extracts information from volumes with broken file systems, damaged partition tables and master boot records (MBR).
I also attached a link to the video instructions and a link to the site
Jun 13, 2013 | Office Equipment & Supplies
Tip
How to use file compration in winxp
How To Use File Compression In Windows Xp
How To Use File Compression in Windows XP
Article ID : 307987
Last Review : July 15, 2004
Revision : 1.1
This article was previously published under Q307987
IN THIS TASK
• SUMMARY
• NTFS Compression
• Compressing an NTFS Volume
• Compressing Files or Folders on NTFS Volume
• Displaying Compressed Files in Color
• REFERENCES
On this Page
SUMMARY SUMMARY
REFERENCES REFERENCES
SUMMARY
Compressing files, folders, and programs decreases their size and reduces the amount of space they use on your volumes or removable storage devices. Volume compression decreases the amount of space that is used by all of the files and folders that are stored on that volume. Because of a potential loss of performance, you may not want to compress some files.
back to the top
NTFS Compression
NTFS compression is available on volumes that use the NTFS file system, and NTFS compression has the following features and limitations:
• You can use NTFS compression to compress individual files and folders, as well as an entire NTFS volume.
• You can compress a folder without compressing its contents.
• You can work with NTFS-compressed files without decompressing them, because they are decompressed and recompressed without user intervention.
• You can display NTFS-compressed file and folder names in a different color to make them easier to identify.
• You may notice a decrease in performance when you work with NTFS-compressed files. When you open a compressed file, Windows automatically decompresses it for you, and when you close the file, Windows compresses it again. This process may decrease your computer performance.
• NTFS-compressed files and folders only remain compressed while they are stored on an NTFS Volume.
• You cannot encrypt an NTFS-compressed file.
You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure. To compressing an NTFS volume:
1. Click Start, then click My Computer.
2. Right-click the volume you want to compress, and then click Properties.
3. On the General tab, click to select the Compress Volume to save disk space check box, and then click OK.
4. In Confirm Attribute Changes, click the option you want.
To compress a file or folder:
1. Click Start, and then click My Computer.
2. Double-click the NTFS Volume that contains the folder or folders you want to compress.
3. Right-click the file or folder you want to compress, and then click Properties.
4. On the General tab, click Advanced.
5. Click to select the Compress contents to save disk space check box, and then click OK.
6. In the Properties dialog box, click OK.
7. In Confirm Attribute Changes, click the option you want.
NOTE: If you move or copy a file into a compressed folder, it is compressed automatically. If you move a file from a different NTFS Volume into a compressed folder, it is also compressed. However, if you move a file from the same NTFS Volume into a compressed folder, the file retains its original state, either compressed or uncompressed.
You can change the display of files and folders that are compressed in Windows Explorer and My Computer, so it is easy to see them. To display compressed files in color:
1. Double-click Folder Options in Control Panel.
2. Click Start, and then click Control Panel.
3. Click Appearance and Themes, and then click Folder Options.
4. On the View tab, click to select the Show encrypted or compressed NTFS files in color check box.
REFERENCES
Windows supports two types of compression, NTFS compression and compression by using the Compressed (zipped) Folders feature.
For additional information about zipped folders, click the article number below to view the article in the Microsoft Knowledge Base:
306531 How To Use Compressed (Zipped) Folders
For additional information about NTFS compression, click the article number below to view the article in the Microsoft Knowledge Base:
251186 Best Practices for NTFS Compression
on Sep 25, 2010 | Computers & Internet
How to recover my tally7.2 company password
Key features
Jun 07, 2013 | Cell Phones
Youtube removed ,how restored n o ki y a E5
5af5bbf4-ede6-42a6-94a0-f75eff3922b9.jpgHetman NTFS Recovery recovers files and folders from all types of hard drives formatted with NTFS, including SSD drives and external storage. The NTFS file recovery tool can perform a simple undelete operation to recover deleted files or perform a comprehensive data recovery procedure, extracting all files and folders from the damaged NTFS volume complete with the original folder structure.
Key features
Apr 30, 2013 | Cell Phones
How to restore factry default settings
Key features
Apr 18, 2013 | Office Equipment & Supplies
Can't find the NTFS Undelete licence key
http://ntfs-undelete.soft32.com/free-download NTFS Undelete 3.0.3 free When you delete a file, its content physically remains intact on the media, but the occupied space becomes marked as free. NTFS Undelete is free software that allows you to recover deleted files. It recovers files directly from hard drive, and ...
Hope this helps.
Dec 15, 2012 | DataNumen Advanced NTFS Undelete
My new seagate go flex hard drive is being read by mac but I cannot do any modification, which includes data transfer!!
Most likely the hard drive is formated as NTFS and you will need to download a 3rd party app in order to write to an NTFS file system in Mac OS X, such as Tuxera NTFS or NTFS For Mac OS X
NTFS For Mac OS X http://www.macupdate.com/app/mac/26288/ntfs-for-mac-os-x
Tuxera NTFS For Mac OS X http://www.tuxera.com/products/tuxera-ntfs-for-mac/
Apr 05, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
I have a WD Elements 1 TB hard drive but i can copy and paste on to the hard drive ,my computer is a Mac Pro
Check to make sure the Hard Drive isn't formated as NTFS if so you won't be able to modify files on the drive without a third party application such as Tuxera NTFS for Mac or NTFS for Mac OS X
Tuxera NTFS for Mac http://www.tuxera.com/products/tuxera-ntfs-for-mac/
NTFS for Mac OS X http://www.macupdate.com/app/mac/26288/ntfs-for-mac-os-x
Mar 31, 2011 | Apple Computers & Internet
System32.ntfs is missing and corrupt
Boot into recovery console, and at the c:\windows prompt type: cd system32 cd drivers ren ntfs.sys ntfs.old If the ntfs.sys file is there and corrupt this will rename it. If it is not there, then it was missing. At the prompt type: copy e:\i386\ntfs.sys c:\windows\system32\drivers\ntfs.sys good luck
Mar 19, 2006 | Apple Power Supply 344 Watt PowerMac G4...
Computers & Internet Logo
David Payne
David Payne
