Question about Denon AVR-3806 Receiver
Don't know how to connect Speakers to a Denon D-250 Amp
Bought a Denon Seperates system 2nd hand but do not know how to connect the speakers to the back of the Amp.
  • Dennis Scroggins May 11, 2010
    I can help but first I need to know your setup details, Surround area only? number of spkrs in surround area, multi room music?
  • 119 Answers
I have a denon avr-4802 receiver. I am looking to purchase new speakers for this system, but don't want to put too much into the speakers. Will the speakers from a denon s-302 work on this receiver? ...
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Denon-S-302-Home-Theater-Systems-manual/id/7046dj484/t/2/
http://www.retrevo.com/support/Denon-AVR-4802-Receivers-manual/id/363ag815/t/2/
Page 10. The S-302 uses a proprietary D-Sub25 system cable to the DSW-S302 subwoofer. Don't know if or why it has more than 2 active conductors. The other speakers have removable cable ends so they might work just fine.
Apr 24, 2011 | Denon AVR-4802 Receiver
I purchase a denon AVR-591 & now i am using speakers from a kenwood home theater system but know all of the speakers work except the subwoofer does not, know the swbwoofer input has a wire Plus Minus...
Take a clue from the bare wire speaker connections on a speaker not matching RCA connectors. RCA is not for feeding +/- speaker terminals on REAL audio equipment.
The Denon requires an active (self-amplified) subwoofer which it feeds a specialized Low Frequency Line Level Pre Out signal.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/avr591.html
Disassembling the parts of HTS and reassigning them to other makes and models is unwise and unpredictable electrically and sound-wise.
Feb 26, 2011 | Audio Players & Recorders
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
The speakers in my new 2nd hand car won't play
if one speaker in car is shorted or bad.It will cause the whole system to mute .You may need to have someone to disconnect one speaker at a time or pull out radio.Some systems have a seperate amp in rear of car .Check fuse for that amp//goodluck
Jul 30, 2009 | Car Audio & Video
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Denon dht500sd surround system
You need to check your speaker wire connections at the speakers and at the amplifier. You must have a positve and negative speaker wires touching. If you check them and still same result you need to unhook all speakers from amp and speakers and hook up one speaker at a time to see if you get message for each speaker and when you finally do you will know which speaker wire and speaker is giving you a problem.
Nov 07, 2008 | Denon DHT500SD System
Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Jun 22, 2008 | Denon AVR-1907 Receiver
Denon Avr-1803- multiple room audio difficulties!
it is true pre amp check your cables and confirm in (avr-1100)that you select the right input.
May 27, 2008 | Denon AVR-1803 Receiver
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
Denon AVR-3806 Receiver Logo
1,467 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
