Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Hi, I'm not able to reinstall wind XP in my PC. Yesterday system was hanged and I got one error. So on that time no buttons were working and shut down directly. Latter when I was trying to open my PC it's not opening and I was trying to reinstall Xp but failed to install and finally when I'm trying to open my PC get one error like" Your computer is checking Hard drive to connect" Please help me to solve this.
It may be a hard disk loose connection problem. I also had the same problem. Just try to open the cabinet and check if the SATA connector is loose. If loose then tight it and try to reinstall the XP.
If not solved, then I assume it is a virus problem.
Posted on Feb 03, 2009
I just uninstalled CA Security and it ask for a reboot and I told it to do it. It is hung up on "Shutting Down" screen. This happened yesterday as I was logging off and it would not "Shut...
Removing the battery is a last ditch move; if you have it hang again, press and hold the power button for ~10 seconds. This will shut down nearly any PC. Restarting the system should shock Windows into repairing the damage to files left screwed up by CA. Some stubborn software may need to be reinstalled and removed again since many programs tinker with registries and other files.
Dec 02, 2010 | HP Computers & Internet
Due to c00002la fatal system error problem I am unable to shut down.
Shut down your PC by pressing restart button then immediately shutdown button, Next time when you start your PC, press F8 during startup before the window logo comes up, and choose "last configuration that worked". If the last known good configuration does not work you may have to reinstall the operating system. Visit this link to resolve this error.
Thanks..!!
Nov 26, 2010 | Computers & Internet
My msi wind wont start!!! i was trying to reinstall my windows using the recovery disk, so restarted my wind but mistakenly pressed f12 instead of f11 to run the boot set-up, but my screen froze (totally...
I'd like to help you, but it is very difficult to diagnose based on your description. We will need to gather more info as we try a few things.
1. Why are you reinstalling? 2. How old is the system? 3. Try the following & let me know the result: turn system back on. When the normal LED indicators are on, press & hold down the power button for 4+ seconds until everything goes off. 4. If step 3 worked, then turn power on & hit bios setup key (f2?). 5. See if HDD is detected.
Jun 07, 2010 | MSI Wind U100-030US Laptop
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
Hai friends........ I am not able to shut down my PC
Ive seen this happen B4..
try holding the power button in..
If your useing the power button every time, it could be sticking,, Or you have it setup to restat when the power button is pushed.
If button is ok and power setting are set right then its *********** board
Dec 01, 2009 | Microsoft Windows XP Professional With...
WINDOWS XP HANGS...
Increase the RAM in the system to at least 1 GB or More to resolve the problem
Nov 27, 2009 | Microsoft Windows XP Home Edition
Pc hangs during shut down
As far as Free Antivirus is concerned, you can download Avira from http://www.free-av.com/ It has the highest detection rates & also extremely light on the system.
May 06, 2009 | Computers & Internet
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
But notify me when critical errors occur
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Windows XP not shutting down.
hi im josh in cebu phils. Friend it is just a simple problem not to be worried of. Actually is not a hang up problem it will shutdown but it takes time.a delayed time or longer time it was set. All you have to do is to go to bios/cmos setup. restart your pc then press f2 if it ask to enter setup or mostly hit del to enter setup. once you have entered the setup you choose the power management then adjust the power off delayed to shorter mins. or you can choose direct off.just select what you want there.it will solve your proble and dont forget to save before you exit so that it will be applied to your pc. hope i helped you good luck!
Feb 19, 2009 | Computers & Internet
Error message on boot up - Error loading operation system
reinstall xp, you wont have another problem for a year or so
Jan 09, 2009 | Dell Inspiron 8600 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
